Massey Hall Is Needing An Addition.
113 replies to this topic
#46 Texas Deere and Horse OFFLINE
  • 14,811 Thanks
  • 15,500 posts
Posted October 10, 2013 - 10:50 PM
Coming along very nicely Will, you do GREAT work.
  • IamSherwood said thank you
#47 toomanytoys84 OFFLINE
toomanytoys84
    Aaron
  • 9,899 Thanks
  • 5,963 posts
Posted October 11, 2013 - 10:05 AM
That is beautiful!
Having your own saw mill would be a lot of work, but having that and timber ready to cut that would be awesome and cheap.
  • IamSherwood and oldedeeres have said thanks
#48 olcowhand ONLINE
  • 41,166 Thanks
  • 31,423 posts
Posted October 11, 2013 - 11:30 AM
Ditto!  Superb!
#49 IamSherwood OFFLINE
  • 8,391 Thanks
Posted October 13, 2013 - 07:12 PM
Nice Will, nice.
So, this is the ELF wing?
I'm kickin around the idea, of making it the Elf/Executive stable. Putting a wiped
yellow stain on the hemlock flooring, would look good, and brighten it up in there
a bit.
Got the rafters up, and a start on the purlins, after work the past few evenings.
I should be ready for the steel roofing, which is scheduled to show up Thurs.
The long range forecast, has those fluffy white things in it for next week. Eeeeeeek..
I'd sure like to get the roof done before that stuff.
Edited by IamSherwood, October 13, 2013 - 07:16 PM.
  • MH81, chris m, Sawdust and 2 others have said thanks
#50 olcowhand ONLINE
  • 41,166 Thanks
  • 31,423 posts
Posted October 13, 2013 - 07:50 PM
I would think it fitting to be the "Elf/Executive Suite".  Plus they would be the easiest to fit in there with plenty of elbow room.   :thumbs:
  • IamSherwood and toomanytoys84 have said thanks
#51 IamSherwood OFFLINE
  • 8,391 Thanks
Posted October 14, 2013 - 08:24 PM
Tonight I got the purlins done. I'm ready for the steel roofing.
I'm thinking about putting in a couple of those translucent skylights,
but am a bit skeptical about their leaking history.
#52 Cat385B ONLINE
    HAZMAT CAT
  • 13,974 Thanks
  • 10,002 posts
Posted October 14, 2013 - 08:27 PM
I am skeptical about those when there is a tree branch within 50', also.
#53 DH1 ONLINE
DH1
    Electric Tractors
  • 5,271 Thanks
  • 5,567 posts
Posted October 14, 2013 - 08:31 PM
Skylights are nice if they don't leak, maybe run a couple sections top to bottom in the roof panels.
#54 olcowhand ONLINE
  • 41,166 Thanks
  • 31,423 posts
Posted October 14, 2013 - 08:34 PM
Will, if you want to be sure of no leaks with the skylights, just put some good quality caulk/sealant where the ribs overlap on each side.  You also want to overlap the steel on the upper end at least 8" or use sealant there also.  I've never had issues with leakage with the screws.  I did have a leak where I didn't have enough overlap on top with the  steel roofing, so sealant stopped that.
#55 IamSherwood OFFLINE
  • 8,391 Thanks
Posted October 14, 2013 - 08:39 PM
I'm probably better off to put my efforts and $ into a better solar system, and
some T8 fluorescents.
Considering I spend more time there in the fall and winter, when there is either
snow on the roof, and/or short days
Edited by IamSherwood, October 14, 2013 - 08:42 PM.
  • twostep said thank you
#56 twostep ONLINE
twostep
    Rockstar
  • 1,985 Thanks
  • 2,536 posts
Posted October 14, 2013 - 09:04 PM
Great looking building.
#57 Texas Deere and Horse OFFLINE
  • 14,811 Thanks
  • 15,500 posts
Posted October 14, 2013 - 10:44 PM
Will, We used those panels in the side walls at the top of the walls and it lets a lot of light during the day with no leaks at all!!
#58 IamSherwood OFFLINE
  • 8,391 Thanks
Posted October 15, 2013 - 12:33 AM
I called my buddy tonight, after posting here. Daylight problem solved.
I have the 2 existing windows (moving into new wall), and I scored  5 more off my buddy tonight.
That should give me plenty of daylight in there.
#59 IamSherwood OFFLINE
  • 8,391 Thanks
Posted October 19, 2013 - 06:44 PM
I got the roof tin on this morning, and then framed in the front wall for the ramp door.
No pic of the ramp door...
Then the rain got the better of me, so I quit.
Thought I'd share this with you too.
The little outlook roof, that has been removed,
was built using this connection.
On the backside of the post a counter bore, and through hole was drilled.
The end of the beam was drilled, and cross drilled.
The threaded rod with flat bar(with a hole in it) then gets slid
through the post, and a pin slipped in the hole and through
the flat bar. Then tightened up. It's a very strong connection.
This is not my idea. I stole it. There's a company out there
that markets something like this. I think they're called Lynx??
  • olcowhand, twostep, oldedeeres and 1 other said thanks
#60 olcowhand ONLINE
  • 41,166 Thanks
  • 31,423 posts
Posted October 19, 2013 - 07:23 PM
I tried working on our patio today too, but like you, the rain got the best of me & I came inside.  Looking great Will!
