Massey Hall Is Needing An Addition.
113 replies to this topic
#31 oldedeeres OFFLINE
oldedeeres
  • 10,483 Thanks
  • 5,093 posts
Posted October 01, 2013 - 01:34 AM
Not as dumb as it sounds, Will. It's truly amazing how fast space fills up.
  • IamSherwood said thank you
#32 IamSherwood OFFLINE
  • 8,395 Thanks
Posted October 04, 2013 - 08:35 PM
I got all the rest of the material milled up the other day.
22pcs. 2 x 6 x 10' 3" rafters
19pcs  2 x 8 x 8' 3" floor joists
about 170' of 2 x 3 purlin mat'l
about 160' of 2 x 4 strapping
enough 3 x 4 and 3 x 7 to make 3 shelves with curved braces.
3 x 6 to brace posts and roof beam
2 x 8 x 13' 6" ridge beams which will get laminated to existing 2 x 8 ridge beam
6 x 6 x 13' posts
4pcs  3 x 9 x 12' 3" floor beams
4 x 6 to support laminated ridge beam
And lots of siding material. 7/8" thick, mostly 10" wide, but there a handful
of 15" wide.
I also got all the 1" x 9" and 10" wide Hemlock flooring done, and sticker/covered
so it starts drying. In a week or so, after the pine needles have stopped
falling, I'll lay some of that tin on the ground beside the stack, in hopes to
reflect some of the sun's heat at the flooring.
Here's some pics of a 20" hemlock being opened up.
First cut done, and log stood up, and squared to blade.
Second cut done. After that, it's easy sailing. Sometimes it takes longer to get
to this point, than to turn the rest of the log into sawdust.
Edging some boards that had wane.
Trimming the last board to thickness. Leftover is 1/8" thick.
About 3/4's of an hour to yield 10pcs of 1" x 10" x 10' 3"
That's a bit over 80 board feet. Rough cut softwood sells
for about a buck a board foot up here. Well worth the effort
considering I'd pay to have the enjoyment of watching
the wood chips fly.
I did take some video too, but I'm having computer grief editing it, and
then I'll have to try to remember how to post it on Utube. Maybe in a few days.
Thanks for looking.
  • olcowhand, MH81, Texas Deere and Horse and 8 others have said thanks
#33 chris m OFFLINE
chris m
  • 3,341 Thanks
  • 4,065 posts
Posted October 04, 2013 - 08:44 PM
That all looks great Will!! But really there was no rush, but since you got it all done are you going to bring it to my house this weekend?? :dancingbanana: :worshippy1: :worshippy1: :worshippy1: :D
Hey a guy can dream right? :D
In all seriousness. That is quiet the set up you have there! And I'll be looking forward to the video. :thumbs:
  • IamSherwood and oldedeeres have said thanks
#34 olcowhand ONLINE
  • 42,897 Thanks
  • 31,941 posts
Posted October 04, 2013 - 08:50 PM
What do you do with the 1/8" thick wood?  That wood is beautiful!
#35 IamSherwood OFFLINE
  • 8,395 Thanks
Posted October 04, 2013 - 09:04 PM
Soak it in water, and laminate it to make skis. :D But that's a whole different story.
  • olcowhand, MH81, Texas Deere and Horse and 6 others have said thanks
#36 shorty ONLINE
shorty
  • 5,833 Thanks
  • 5,414 posts
Posted October 05, 2013 - 07:04 AM
Nice looking ski. is that the set for the tractors?
#37 twostep OFFLINE
twostep
    Rockstar
  • 1,988 Thanks
  • 2,539 posts
Posted October 05, 2013 - 07:18 AM
Now you've got me thinking, that I should add on to the addition, before it's built. :rolling:  :rolling:
That is where I'm screwing up with my shed... I've already got 90% of the floor space assigned.
#38 IamSherwood OFFLINE
  • 8,395 Thanks
Posted October 09, 2013 - 09:21 PM
I managed to steal the last 2 days off work, so I got the tools out
and started to build.
First I took the gangplank door off, and cut/removed the bottom of
the siding, to expose the existing floor joists.
Then bolted the 3 x 9 beams in place.
Next, notched the top of the posts, and braced them in place.
Then added the outer floor beams.
Floor joists.
Next I had to remove that little outlook roof. I managed to get the
rafters and purlins off in 2 sections, so I can reuse them.
The outer beam on that roof is slated to sit on top of my new posts.
I got the outer beam in place, part of the ridge beam in place, and
the first rafter set. Now I can order the tin steel roofing.
Of course, ELF had to come out, and check out his new pad. :smilewink:
  • olcowhand, MH81, Alc and 6 others have said thanks
#39 Cat385B ONLINE
    HAZMAT CAT
  • 14,370 Thanks
  • 10,139 posts
Posted October 09, 2013 - 09:46 PM
Good thing you had that ledger board on, or he might of made a run for the N Pole!
Coming along very nice. Looks kinda small, though.
Hahahahahaha
#40 MH81 OFFLINE
  • 29,978 Thanks
Posted October 09, 2013 - 09:53 PM
Nice Will, nice.
So, this is the ELF wing?
#41 IamSherwood OFFLINE
  • 8,395 Thanks
Posted October 09, 2013 - 09:55 PM
Hahahahahaha
Yes, it does, doesn't it.
It'll do for a year or so, then I'll lengthen the hole building.
  • Alc and Cat385B have said thanks
#42 HowardsMF155 ONLINE
  • 2,963 Thanks
  • 3,017 posts
Posted October 09, 2013 - 09:59 PM
So I guess you could consider that a sort of "Elf Shelf" then?  And your Massey will be the Elf on the Shelf!
#43 oldedeeres OFFLINE
oldedeeres
  • 10,483 Thanks
  • 5,093 posts
Posted October 10, 2013 - 01:24 AM
That's a lucky Elf, but the addition won't be big enough when he grows up,  lol
#44 KennyP ONLINE
  • 40,891 Thanks
  • 47,096 posts
Posted October 10, 2013 - 05:44 AM
Looking good, Will. Glad Elf likes it!
#45 UncleWillie OFFLINE
  • 16,253 Thanks
  • 8,970 posts
Posted October 10, 2013 - 10:41 PM
Great work
