Who Has A Pipe Roller?
19 replies to this topic
#1 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted September 28, 2013 - 07:27 PM
Anyone here have a pipe roller capable of roll bending some pipe into a 12 inch diameter circle for use as a steering wheel, as I am thinking of building my own steering wheel right now.
#2 olcowhand OFFLINE
  • 41,134 Thanks
  • 31,413 posts
Posted September 28, 2013 - 07:35 PM
Just have Uncle Willie find a 12" diameter fence post, then he can simply grab a correct size pipe & whack the pipe on the post.  You may end up with a couple rounds around the post, but once pried off you can cut & weld a couple at once!
  • UncleWillie said thank you
  • 14,811 Thanks
  • 15,499 posts
Posted September 28, 2013 - 09:03 PM
Casey, A good muffler shop can do it, maybe in 2 pieces.
  • wvbuzzmaster said thank you
#4 olcowhand OFFLINE
  • 41,134 Thanks
  • 31,413 posts
Posted September 28, 2013 - 09:35 PM
Actually, if you had a car rim about the right size (at it's center) anchored solid, you could weld a loop on it to hold the end of a pipe, then just pull the pipe around till the ends pass a few inches.  Then cut the straight ends back to where things are curved, pull the ends together and weld.  I've bent pipe using car rims before.  Never made a steering wheel though.
  • wvbuzzmaster and SupplySergeant have said thanks
#5 olcowhand OFFLINE
  • 41,134 Thanks
  • 31,413 posts
Posted September 28, 2013 - 09:38 PM
Dang, my left shoulder is hurting.  Maybe I shouldn't have tested my post pipe bending theory!   :smilewink:   Naw, didn't actually try it, but my shoulder IS hurting, and why... I don't have a clue.
#6 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,295 Thanks
  • 9,777 posts
Posted September 29, 2013 - 07:00 AM
Can we see the str. wheel when your done?
#7 MH81 OFFLINE
Posted September 29, 2013 - 07:28 AM
Casey, I was thinking about this... You're going for unique, one of a kind here... Why not something like this?
#8 olcowhand OFFLINE
  • 41,134 Thanks
  • 31,413 posts
Posted September 29, 2013 - 07:32 AM
Or a large pulley or old gear.
  • Cvans said thank you
#9 MH81 OFFLINE
Posted September 29, 2013 - 07:46 AM
I have a different idea.
#10 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,295 Thanks
  • 9,777 posts
Posted September 29, 2013 - 08:30 AM
If the wheels jerk, that is really going to hurt! Worse than a spinner knob.
Edited by LilysDad, September 29, 2013 - 08:30 AM.
#11 Cvans OFFLINE
  • 6,648 Thanks
  • 6,128 posts
Posted September 29, 2013 - 07:23 PM
The pulley would be the best as it would help support the sidewall and keep the pipe from crushing. Used this method a couple of times with good results.
#12 Alc ONLINE
  • 6,884 Thanks
  • 7,459 posts
Posted September 30, 2013 - 05:55 AM
I saw a sheet metal slip roller for sale  at a show last week and at the one end it had groves in the rollers , the biggist maybe 1/2 wide , would that have rolled tubing or just soild rod ?
#13 dogsoldier OFFLINE
dogsoldier
  • 361 Thanks
  • 509 posts
Posted September 30, 2013 - 01:50 PM
i have a couple that i used when i raced go karts that are just sittin around gathering dust. if you want to see pics i can take a couple and post them
#14 Texas Deere and Horse OFFLINE
  • 14,811 Thanks
  • 15,499 posts
Posted September 30, 2013 - 03:03 PM
Casey, On small DIA. thin wall pipe, just use a conduit bender. I have seen benders from 1/2" to 1 1/2".
#15 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted September 30, 2013 - 06:36 PM
Brian, i had thought about that method but was thinking about more controled methods.
