Turning Radius
3 replies to this topic
#1 akretowicz OFFLINE
akretowicz
  • 236 Thanks
  • 316 posts
Posted September 28, 2013 - 07:10 PM
Am curious as to if I can reduce the turning radius of my 1054.  I know that one of Cub's selling points is it's tight turning radius, but mine turns so tight it leaves marks in the ground.  I have never had a tractor tear into the ground while turning.  Bottom line is it turns too sharp!  I even try feathering the wheel while turning.  Not good.  I am at the point now that I just stop, back up, and go my merry way.  Any ideas?
  • Dieselcubmike said thank you
#2 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted September 28, 2013 - 08:34 PM
I think the simple solution is to learn your machine.  Its the same way with zero turn mowers.  You can tear the ground up if you aren't careful.  I participate in selling zero turns, and that's the first thing a new owner does.  You can tell where he went around his trees.
You'll get the hang of it.  Don't cut it down, there might be (and will be) a time you will need that tight turn!
Ben W.
  • Alc and akretowicz have said thanks
#3 DH1 ONLINE
DH1
    Electric Tractors
  • 5,415 Thanks
  • 5,616 posts
Posted September 28, 2013 - 08:35 PM
Check the toe in toe out, sometimes if there is too much toe in the tires dig in more.
#4 Gtractor OFFLINE
Gtractor
    the homeless tractor hoarder
  • 9,796 Thanks
  • 5,094 posts
Posted September 28, 2013 - 09:08 PM
You might do a quick check to make sure the steering geometry is correct.  That ensures both steer tires are working together instead of against each other.   Good Luck!!
http://en.wikipedia....ermann_steering
  • akretowicz and superaben have said thanks
