Drive Shaft Questions...
8 replies to this topic
#1 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted September 28, 2013 - 04:46 PM
Let's say I put an engine into a gt. If the engine shaft isn't centered with the hydro shaft I'll get vibration correct. Do they use ujoints and/or rag joints to eliminate the drive shaft angles? It seems the snapper with rubber engine mounts and a almost solid drive shaft seems like a bad idea.
Sent from my SCH-I535 using Tapatalk 4
  • JRJ said thank you
#2 TAHOE ONLINE
TAHOE
  • 7,970 Thanks
  • 5,673 posts
Posted September 28, 2013 - 06:31 PM
I think Snapper used the rubber isolator motor mounts to reduce motor vibration to rest of tractor. Your driveshaft has u joints as there is a slight pitch between motor and pump, like a car tranny driveshaft. I think the 1650 is direct connection from motor to pump, my 1855 has a set of pulley the pivot and drive off motor and driveshaft them connects to pulleys and back to pump, talk about a lot of possibly issues and parts to wear out....and expensive.
  • BairleaFarm said thank you
#3 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted September 28, 2013 - 06:39 PM
When there is a difference in height between the engine crankshaft and the transmission input shaft you have to use U joints. One of the big issues I have with finding a re power engine for my JD314 is that it does not have u joints so the shaft height is critical. It has fibreglass discs at each end of the shaft to deal with the movement of the engine. The JD317 I have uses U joints so if I re power it would be easier to match up another engine to the shaft.
#4 nbent ONLINE
nbent
    customizer
  • 673 Thanks
  • 538 posts
Posted September 28, 2013 - 07:00 PM
most gts i have have u joints from the factory, but on my 317 it was repowered and had a solid shaft that wore out so after looking for a cheap factory shaft i settled on part of a steering column from an older chevy pickup it has a cv joint on one end and a rag joint on the other
  • Alc and BairleaFarm have said thanks
#5 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted September 28, 2013 - 07:22 PM
So if using u joints I can be a little off on my drive line and it would be ok?
#6 olcowhand ONLINE
  • 41,081 Thanks
  • 31,393 posts
Posted September 28, 2013 - 07:31 PM
Yes, U-joints is the way to go IF you aren't going to use your rear pto.  Using a U-joint & side loading them with the pto pulley drive system WILL give problems.  The Snapper & Massey do not have any sort of flex joint due to having rear pto.  The rubber engine mounts ARE a bad design in my opinion with the semi-solid shaft assemblies.
#7 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted September 28, 2013 - 07:58 PM
I don't have a rear pto on the snapper. I wasn't necessarily talking about that gt. I am thinking about possibilities for the cub. Long term the snapper is also on my mind.
#8 olcowhand ONLINE
  • 41,081 Thanks
  • 31,393 posts
Posted September 28, 2013 - 08:00 PM
Then go with U-joints & you won't regret it.  You can have a good angle & still run smooth as silk.
  • BairleaFarm and SupplySergeant have said thanks
#9 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted September 28, 2013 - 08:08 PM
Thanks. All these thoughts of future project possibilities lol
