1250 Winter Project
45 replies to this topic
#16 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted September 29, 2013 - 06:22 PM
I could possibly make it fit. I like the looks of the dash tower with no handles on the side. I would rather it be on the fender but doing that and making it look and function well could be hard.
Sent from my SCH-I535 using Tapatalk 4
#17 IHCubGuy OFFLINE
IHCubGuy
  • 1,500 Thanks
  • 1,579 posts
Posted September 29, 2013 - 07:33 PM
Maybe mount it under the fender or the seat and just have the handle stick up thru the fender that you could put a rubber boot on to dress up.  I know a guy that had a 123 with hydraulics on it like that at one time.  Don't know if he still does or not but it was a clean job that you would have swore was factory.
#18 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted September 29, 2013 - 07:44 PM
I've thought about mouthing a small ammo box on the fender. One I could have a toolbox abd two it would be a place to put the spool valve. I know it wouldn't be factory looking but it could turn out ok I think. There isn't alot of room under the fender. I think tire clearance would be a issue. I'll have to play around with it and see.
#19 CubHorse80 OFFLINE
CubHorse80
  • 159 Thanks
  • 318 posts
Posted September 30, 2013 - 06:46 AM
Should be a fun project! Good luck!
  • BairleaFarm said thank you
#20 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted September 30, 2013 - 06:41 PM
Hauled the 16 in the shop and heave hoed it on the work bench. Starter and regulator bolted on. Starter seems to drag. Added points...
While checking the carb I noticed a ton of play in the throttle shaft.
  • CubHorse80 said thank you
#21 CubHorse80 OFFLINE
CubHorse80
  • 159 Thanks
  • 318 posts
Posted October 01, 2013 - 08:05 AM
are you talking about the governor linkage that connects to the throttle? Is it loose in the block? If so, then it needs a new bushing pressed into the block. Otherwise it could leak oil, and the throttle will be sloppy.
#22 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted October 01, 2013 - 10:00 AM
The whole shaft.
#23 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted October 02, 2013 - 07:48 PM
I know the linkage piece on top of the shaft is loose but what about the shaft itself? Like mentioned before it's there a bushing? It looks like it.
#24 TAHOE OFFLINE
TAHOE
  • 7,808 Thanks
  • 5,610 posts
Posted October 02, 2013 - 08:08 PM
Wow, that shaft is about to fall out. I know the Walbro carbs have bushings on both ends, but yours are gone including some of the shaft and carb hole :D  Just kidding, but never seen that much play in one.
Love those tires, nice and square and you got dual rear brakes!
#25 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted October 02, 2013 - 08:17 PM
The brakes don't work. I need to fix that and one day maybe put steer brakes on get Bobby said that the po said this engine smoked. I wonder if that could be the issue?
Edited by BairleaFarm, October 02, 2013 - 08:19 PM.
#26 IHCubGuy OFFLINE
IHCubGuy
  • 1,500 Thanks
  • 1,579 posts
Posted October 02, 2013 - 09:44 PM
I'd say that carb needs a complete rebuild.  New throttle shaft and bushings and possibly needles.  Never seen that much play in one of them.  If you are worried about the engine smoking I would run it first and check the smoke.  If it is the carb it will be black smoke.  If it's oil it will be blueish smoke.  If the motor checks out ok then I would move ahead with the carb rebuild.
#27 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted October 02, 2013 - 10:02 PM
Will a 10 or 12hp carb work on this engine?
#28 IHCubGuy OFFLINE
IHCubGuy
  • 1,500 Thanks
  • 1,579 posts
Posted October 02, 2013 - 10:33 PM
16hp has a number 30 carb on it whereas the 10 and 12hp's have a number 26 on them.
As for the brakes I would check all the linkage for binding and get them all free'd up and then get them readjusted per the manual.  I couldn't find the manual you need here on the site but did find it at one of my other haunts if you need one.
http://www.cubcadetc...etail&df_id=272
#29 johncub7172 OFFLINE
johncub7172
  • 12 Thanks
  • 10 posts
Posted October 04, 2013 - 08:09 PM
Nice project! How do you plan to paint it? I use a sealer, primer, and then a Cub Cadet paint. A Dayton heater flashes the Cub Cadet paint, and the out come of quality is second to none. Take my word for it! The factory paint on one of my tractors is over 47 years old, and still looks good. But it can be expensive. Well, good luck!
#30 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted October 27, 2013 - 09:05 PM
The 341 I planned to put in this will go to fix the massey. While I'm not fond of using the 12hp I know it's a good running engine. I don't plan on plowing or anything with this so the 12 should be plenty for general yard duty. As far as the paint I'm not sure. I'll cross that road when I get there.
Edited by BairleaFarm, October 27, 2013 - 09:06 PM.
