Bolens Tiller
2 replies to this topic
#1 Justin2655 OFFLINE
Justin2655
  • 204 Thanks
  • 148 posts
Posted September 28, 2013 - 12:32 PM
i just got a 1050 package with tiller and blower, would you use bolts or pins to put the tiller on? not sure if it really matters but id rather be safe then sorry and not bust the brackets off the rear end, thanks
#2 boyscout862 OFFLINE
  • 12,864 Thanks
  • 9,175 posts
Posted September 28, 2013 - 01:11 PM
Pics or you don't really own it. Pins would be better, the smooth surface of a pin will wear less on the tractor than the edges of a threaded bolt. You can download the manuals from our manuals section. That is a great tractor.. Be sure to lubricate all of the steering places. At the base of the steering wheel is one that is a PIA but you have to do it or it will seize up. Good Luck, Rick
#3 wilberj ONLINE
wilberj
  • 5,003 Thanks
  • 5,595 posts
Posted September 28, 2013 - 03:21 PM
Pins are whats used on them use the right size to.
