The Compression Test
31 replies to this topic
#16 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,329 Thanks
  • 9,795 posts
Posted September 28, 2013 - 06:40 PM
I once had a Kohler 301 that wouldn't start/run. It drove me nuts troubleshooting it. Finally using a multi-meter, I found that one of the wires on the coil was tarnished, not corroded, tarnished. I polished it and all was good.
The moral: check everything!
#17 Alc ONLINE
  • 6,905 Thanks
  • 7,468 posts
Posted September 28, 2013 - 08:32 PM
Is  there  anyway  on this engine that  you could check the  timing   with a timing  light ,  wasn't   there a tool you would put in the spark plug hole and whistle  when tdc  then you could mark a pulley and then crank and see how close it   was
http://www.toolaid.c...enter-indicator
Found the tool
Edited by Alc, September 28, 2013 - 08:38 PM.
#18 UncleWillie ONLINE
  • 15,676 Thanks
  • 8,763 posts
Posted September 28, 2013 - 09:42 PM
This one is cheaper
  • MH81, OldBuzzard, Alc and 3 others have said thanks
#19 AVB OFFLINE
AVB
  • 138 Thanks
  • 135 posts
Posted September 28, 2013 - 10:59 PM
How do you know it is firing under compression?  I agree with the others pull the cowling and check the fly wheel.
Those are my thoughts, check timing, and replace spark plugs. Do you have another engine that you can test the spark plugs in, or borrow the spark plugs to try in this engine?
Or another option is to use an inline spark tester. Even without an actual inline spark tester you could ground a regular spark tester to the spark plug terminal to use it as an inline tester as long as the gap isn't too large.
Edited by AVB, September 28, 2013 - 11:07 PM.
#20 MH81 OFFLINE
Posted September 29, 2013 - 08:18 AM
This one is cheaper
Ryan and I watched that twice, laughing.
Way to use your thinker Willie!
#21 John@Reliable OFFLINE
John@Reliable
  • 1,298 Thanks
  • 1,416 posts
Posted September 29, 2013 - 08:22 AM
Get rid of the E3 plugs, you might be surprised as they seem to foul real easy.
#22 Alc ONLINE
  • 6,905 Thanks
  • 7,468 posts
Posted September 29, 2013 - 08:46 AM
I guess i'm dumb but what are E3 plugs ?   Willie , can't wait until the dog gets a new toy because the first thing he does is try getting the squeeker out and I'll  make one like yours ,
#23 John@Reliable OFFLINE
John@Reliable
  • 1,298 Thanks
  • 1,416 posts
Posted September 29, 2013 - 10:59 AM
Best thing since sliced bread :De3.jpg
In theory more spark area should be a good thing, >>> But in reality they don't hold up well and foul easy. I've tried them a few times in a pinch until I could get a standard plug.
#24 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted September 29, 2013 - 01:18 PM
Took the engine off and took it down to the flywheel and inspected the key, which was in perfect condition, even the Briggs logo stamped into the side looked new. So it isn't that and the gap on the magneto looks good still, going todoublebcheck it though. The magnet is fine, still as clean as the day I cleaned it up for the new magneto. It isn't perfectly clean but I didn't want o risk degagnetizing it. So I have checking it all, and the E3 plugs are staying, it isn't those, they are making spark. I don't know what is wrong with the engine, but ready to give up on it and buy a new Briggs Vanguard to swap in to the tractor.
#25 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,329 Thanks
  • 9,795 posts
Posted September 29, 2013 - 06:17 PM
Oh, that would be way too easy. We're just getting started on this. How about making this a contest with the winner getting a free subscription to GTTalk???
#26 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted September 29, 2013 - 06:40 PM
This is an ongoing problem with this tractor.
#27 DH1 ONLINE
DH1
    Electric Tractors
  • 5,272 Thanks
  • 5,567 posts
Posted September 29, 2013 - 06:55 PM
Casey you should try a different set of plugs in that engine, I had one of those 18hp opposed twins for 8yrs, most reliable, consistent engine I had,I never changed the plugs, I think it had Champions in it.
#28 bread320i OFFLINE
bread320i
  • 613 Thanks
  • 1,225 posts
Posted September 29, 2013 - 07:10 PM
This summer I learned that not all spark plugs are good.
I was working on an old rope start Wisconsin Engine. I darn near pulled my are off trying to get it running. I had spark fuel and compression. I figured any spark was good enough to run.
Well I changed the plug per the wifes request and it started on the first pull.
At a minimum pull plugs off a running tractor and see what happens.
  • HDWildBill said thank you
#29 Alc ONLINE
  • 6,905 Thanks
  • 7,468 posts
Posted September 30, 2013 - 05:50 AM
Casey , did you ever find the compression specs ? With the ignition disabled choke and throttle wide open will it pull a good vacuum with you hand over the carb ? Just trying to think of things to try if it doesn't work with new plugs . And I still don't belive your dad hasn't figured it out ,,, or maybe he knows and he's pissed at you lol   Good luck
#30 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted September 30, 2013 - 09:46 PM
No, never found what the compression is supposed to be. Dad has been mentoring me a little from afar but I have been getting more and more disgusted with the tractor (engine). I'm ready to replace the engine, dad doesn't think I should give up. PersonaLy, I don't know if this engine has 500 hours, 1500 hours, or 2500 hours. I mean the tractor has had a roughish life before I got it. I mean I can plop a new vanguard on it and an hour meter and it could last me 25 years trouble free. I'm convinced ive probably spent 300 - 500 trying to fix this recurring issue, that's part way to a new vanguard....
