A Couple Kawasaki Questions
8 replies to this topic
#1 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted September 27, 2013 - 09:35 PM
1. I've got the side shaft engine from the mule. It has two studs that holds the muffler on. Flanged I guess. It's there a local source for a exhaust flange? I want to put a after market exhaust.
2. On a John Deere 318. Do the coils have a positive and a negative wire? Or a ground and a trigger wire?
Sent from my SCH-I535 using Tapatalk 4
#2 olcowhand ONLINE
  • 40,373 Thanks
  • 31,177 posts
Posted September 27, 2013 - 10:16 PM
No idea as to flange source.  The early 318's had points, so a std type coil.  Later models had the pointless ignition.....the negative went to the trigger module, + to the IGN terminal.
#3 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted September 27, 2013 - 10:32 PM
No standard coil on this one. I would assume the little box on the left side of the engine is the trigger. Thanks
#4 WNYTractorTinkerer OFFLINE
WNYTractorTinkerer
    Tinker Master
  • 10,220 Thanks
  • 5,681 posts
Posted September 28, 2013 - 12:04 AM
The 'Trigger' is called an 'Igniter'..  It breaks the primary coil winding like a set of points do..
BTW--  I think 'Trigger' was the Duke's horse!!   :smilewink:
As far as the flange goes, Those engines are used on a variety of motorized vehicles like Gator's and such..  Look around and I'll bet you can come up with something..  Measure the flange inner and outer dimensions (height & width) and pipe size and shop around.  EB may have something you may be able to make work or you could have a flange/pipe made up @ a muffler shop..
#5 Guest_gravely-power_*
  • Guests
Posted September 28, 2013 - 01:53 AM
'Trigger' was Roy Rogers' horse.
  • WNYTractorTinkerer and superaben have said thanks
#6 WNYTractorTinkerer OFFLINE
WNYTractorTinkerer
    Tinker Master
  • 10,220 Thanks
  • 5,681 posts
Posted September 28, 2013 - 03:13 AM
I stand corrected.. :worshippy1:
Thanks!
#7 HDWildBill OFFLINE
  • 8,975 Thanks
Posted September 28, 2013 - 11:50 AM
You could probably use an ATV or MC exhaust if you are looking to do a custom exhaust.
#8 olcowhand OFFLINE
  • 40,373 Thanks
  • 31,177 posts
Posted September 28, 2013 - 03:40 PM
I forgot we were talking about a Kawasaki engine.  I was thinking Onan due to the JD318 mentioned.
#9 BairleaFarm ONLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted September 28, 2013 - 03:53 PM
Yes its the water cooled one
