Sickle Bar Mower For Massey/snapper 1650?
6 replies to this topic
#1 gtcsreg OFFLINE
gtcsreg
  • 2149 Thanks
  • 2111 posts
Posted September 27, 2013 - 09:00 PM
I have seen a sickle bar for say a MF 12 (see picture below).  Is there that fits a MF/Snapper 1650 for mid mount?  Any other make that will work?
Thanks,
Reg
#2 olcowhand OFFLINE
  • 44102 Thanks
  • 32301 posts
Posted September 27, 2013 - 10:21 PM
I don't know of any, but I don't know everything either.  But I do know one could be adapted.
  • gtcsreg said thank you
#3 gtcsreg OFFLINE
gtcsreg
  • 2149 Thanks
  • 2111 posts
Posted September 28, 2013 - 07:57 PM
Ok just got a lead on a Bolens 4 foot side mount sickle bar for about $200.  Good deal?  Good choice to adapt to the 1650/
#4 olcowhand OFFLINE
  • 44102 Thanks
  • 32301 posts
Posted September 28, 2013 - 08:02 PM
Any sickle mower in decent shape is worth that price.  Most any can be adapted if you have the tools & ability, plus patience.
#5 gtcsreg OFFLINE
gtcsreg
  • 2149 Thanks
  • 2111 posts
Posted September 28, 2013 - 08:23 PM
I can overhaul an engine and do some fabrication but no welder even though I can weld. Patience for fit, alignment, and adjustment? Would adapting a walk behind sickle bar for the front be any easier?
Edited by gtcsreg, September 28, 2013 - 08:24 PM.
#6 olcowhand OFFLINE
  • 44102 Thanks
  • 32301 posts
Posted September 28, 2013 - 09:48 PM
The patience is more for sitting & getting things figured out as well as possible in your head or onto paper BEFORE doing a single thing toward actual work.  The best spot is mid-side of the tractor as most are on GT's.  Directly in front like walk-behinds doesn't work as well because the stuff can't fall off the back as well with the tractor so near.  Out behind the tractor has you twisting your neck a lot to see where you are & how the cut is doing.  Right down beside & slightly forward of you is easy to see & easier to maneuver, and off to the side lets the cut stuff fall backwards over the sickle so much better.  Alignment is the most critical part.  Getting the belt to align properly from the mule drive is crucial.  A welder is almost a must, but my Dad built GT's from car parts & didn't even have a welder at the time.  He drilled & bolted it entirely.
#7 gtcsreg OFFLINE
gtcsreg
  • 2149 Thanks
  • 2111 posts
Posted October 03, 2013 - 04:14 PM
Just thought to look through old ads you could download on GTT.  Looks like they did.  Now to find one.  Yes, I sometimes dream big.
