I Recently Purchased An Allis 816Gt W/ The Twin 16Hp Briggs
16hp twin 816gt
2 replies to this topic
#1 Dougiefish OFFLINE
Dougiefish
  • 2 Thanks
  • 2 posts
Posted September 27, 2013 - 11:23 AM
I have fallen in love with this tractor. The 48" deck cuts beautifully! However, the twin 16 smokes a bit at start up and seems to lack a little bit on power. I know they don't make these engines any longer but I was wondering if rebuild parts are still available. Also if the motor is even considered rebuild-able? I have found some great info on here and am looking forward to these discussions!
  • JRJ and Sawdust have said thanks
#2 boyscout862 ONLINE
  • 12,529 Thanks
  • 9,032 posts
Posted September 27, 2013 - 02:30 PM
Welcome to GTT. You can download the manual from our Manuals Section. Parts are available. Before you even worry about rebuilding, do a complete servicing. Change oil and use 30w oil. Tune it up(electrical and carboration). Remove the tin and clean all cooling fins. Add Marvel Mystery Oil(MMO) to the gas at 1/2 ounce per gallon and run it for a few more cuttings. The smoking can be caused by too rich of a fuel mixture or stuck rings. The tuneup should remedy the mixture and MMO should free the rings. A full rebuild kit is probably available from one of our sponsors. Good Luck, Rick
Check your crankcase breather for proper operation too.
Edited by boyscout862, September 27, 2013 - 02:33 PM.
  • skunkhome and Sawdust have said thanks
#3 TAHOE ONLINE
TAHOE
  • 7,811 Thanks
  • 5,611 posts
Posted September 27, 2013 - 03:12 PM
Yea, the Allis I grew up with was the best cutting tractor I've ever used. I will rebuild it one of these days.
It's possible to find rebuild parts, just have to search. If it's just smoking a little then Iwould say it would rebuild easily, maybe some light machine work. The "un-rebuildable" ones are usually those with a hole in the side of the block.
