Db 8" Plow Repairs
10 replies to this topic
#1 Alc ONLINE
  • 6,905 Thanks
  • 7,468 posts
Posted September 26, 2013 - 08:42 PM
I never could plow a straight furor with the DB 600 (  walkbehind ) tractor I was always fighting with it . Then noticed the plow and beam didn't seem straight so I posted  the question http://gardentractor...-plow-question/
if was like that from the factory or not and yep it's bent lol . I tried bending it back and it helped a little but I'm thinking the steel is now soft . Once I took it apart you could really tell even now it needs to be straighter . I used a piece of 3/8" x 2" flatstock to reinforce it .I had a heck of a time getting the welder to work right , it wasn't until I was almost done I figured out what it was ,,the tip was pinching down on the wire and keeping it from feeding correctly :wallbanging:   why do we find the problem at the end of the job lol A quicky paint , put it back together and I'll see if it makes a difference this weekend
  • MH81 and boyscout862 have said thanks
#2 MH81 OFFLINE
Posted September 26, 2013 - 10:37 PM
Wow Al, looks a lot straighter now! Hope the plow pays you back with nice furrows and a fun time.
#3 KennyP ONLINE
  • 38,473 Thanks
  • 45,969 posts
Posted September 27, 2013 - 05:42 AM
Nice fix! Hope it works for you!
#4 Alc ONLINE
  • 6,905 Thanks
  • 7,468 posts
Posted September 27, 2013 - 10:33 AM
Goofed up a little , I should cut out the area where the plow piviots on the beam before welding it , I ended up grinding most of the weld away :wallbanging:  , you can see the cut out section in the 3 rd picture  where the ground clamp is ,  still welded on the other side and not cut out . On the plus side I didn't cut it to length until after I heated , bent and welded it . That gave me some leverage when heated .
#5 Alc ONLINE
  • 6,905 Thanks
  • 7,468 posts
Posted September 28, 2013 - 08:39 AM
All back together , tried  it out  but couldn't  really good  test because of only running  one furor   in the garden , still too much growing  and the other sections  already have the   winter rye  cover crop growing   , once the tomatoes and sweet potatoes  are done I try it again
#6 Alc ONLINE
  • 6,905 Thanks
  • 7,468 posts
Posted September 28, 2013 - 09:21 AM
Another thing I might  need to do is the rollers are really worn both   inside and outside , this plow was a worker lol  . My brother picked up 6" plow and  will be bringing it up next weekend  , I'll take  those off it if they are better
  • 14,814 Thanks
  • 15,501 posts
Posted September 28, 2013 - 11:42 PM
Al, The beam looks good and straight now, Hope that fixed your problems.
#8 MH81 OFFLINE
Posted September 29, 2013 - 06:50 AM
Hey Al, you're welcome to come over and try it here :D
#9 Alc ONLINE
  • 6,905 Thanks
  • 7,468 posts
Posted September 29, 2013 - 08:49 AM
Your a little too far  ,  how about  next years PA Plow Days ?   I  saw some walkbehinds in the practice/set-up   area  .
#10 MH81 OFFLINE
Posted September 29, 2013 - 08:58 AM
I'm sure someone could find some dirt somewhere.
#11 KennyP ONLINE
  • 38,473 Thanks
  • 45,969 posts
Posted September 29, 2013 - 09:43 AM
I know of some in Kentucky!
