Hydraulic Pump Leaking
7 replies to this topic
#1 dropped82 ONLINE
dropped82
    Nut Case
  • 1,986 Thanks
  • 1,530 posts
Posted September 25, 2013 - 03:30 PM
Well towards the end of the Ball Hollow plow day, I developed a small leak on the 442. After further investigation it looks like its coming from the pump. It also seems that I can remove the back plate and reseal the spot that is leaking. What does everybody think I should use? I don't know where to start to look. Maybe the copper gasket maker? Any suggestions?
Eric
Sent from my SPH-D700 using Tapatalk 2
  • 14,499 Thanks
  • 15,397 posts
Posted September 25, 2013 - 03:41 PM
Eric, There may be an O-ring inside the plate to seal the pump. I would get it apart then figure out what you need.
  • dropped82 said thank you
#3 dropped82 ONLINE
dropped82
    Nut Case
  • 1,986 Thanks
  • 1,530 posts
Posted September 25, 2013 - 03:46 PM
I'm hoping its that easy. I'm gonna tear into it tonight. Should be fairly simple to get out. Its just under the battery. Thanks.
Eric
#4 Texas Deere and Horse ONLINE
  • 14,499 Thanks
  • 15,397 posts
Posted September 25, 2013 - 03:51 PM
Most pumps use an O-ring instead of a gasket like we are used to.
#5 dropped82 ONLINE
dropped82
    Nut Case
  • 1,986 Thanks
  • 1,530 posts
Posted September 25, 2013 - 10:19 PM
Well it was a good night. Got started on removing the pump. Removed the battery. Then proceeded to remove the output line on the pump. What do you know, it loose!!! That made for an easy repair. Got it good and tight. No leaks. Also adjusted the brake. It works good now. At least for parking. Looked at the wiring and tomorrow I will hook the headlights up threw the key switch like they should be.
Eric
#6 Alc ONLINE
  • 6,125 Thanks
  • 7,027 posts
Posted September 26, 2013 - 05:41 AM
Glad to hear  it was an easy fix !  It's great when it happens like that sometimes
#7 MH81 ONLINE
  • 29,438 Thanks
  • 29,544 posts
Posted September 26, 2013 - 06:35 AM
So it really WAS a loose nut behind the wheel... Just on the other side of the dash :smilewink:
Glad it was a simple fix, nice when a guy gets lucky on stuff like this. :thumbs:
#8 Texas Deere and Horse ONLINE
  • 14,499 Thanks
  • 15,397 posts
Posted September 26, 2013 - 09:10 AM
Great news, glad you didn't have to pull the pump.
