Are My Feet Just Too Big Or...
17 replies to this topic
#1 32spec OFFLINE
32spec
  • 22 Thanks
  • 24 posts
Posted September 24, 2013 - 07:03 PM
The brake pedals are too close too together so I can't work the pedals separately when wearing my boots.  Anyone else have this problem?  Any solutions?  Thanks
Jeff
  • JRJ said thank you
#2 Gtractor ONLINE
Gtractor
    G-agressive tractor
  • 9,347 Thanks
  • 4,960 posts
Posted September 24, 2013 - 07:22 PM
The guy that designed the brake pedals on Power Kings is the same guy that makes the handles for portable air compressors and battery chargers on wheels.  :wallbanging:  :(  :mad2:
  • GTTinkerer and 32spec have said thanks
#3 toomanytoys84 ONLINE
toomanytoys84
    Aaron
  • 9,927 Thanks
  • 5,976 posts
Posted September 24, 2013 - 07:41 PM
I have a size 11.5 boot and I cant fit mine on them separately
  • 32spec said thank you
#4 UncleWillie ONLINE
  • 15,676 Thanks
  • 8,763 posts
Posted September 24, 2013 - 07:43 PM
Strap a board to your boot to work the pedals.
#5 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted September 24, 2013 - 07:52 PM
This was normal on the tractors up until the early 80's when they replaced those little discs with big boy pedals.  Soon you'll learn how to twist your leg in order to hit one pedal.  I did that for so many years that I still do it on any tractor I use.  It's just one of those things that tell you you're on a PK.
#6 Guest_gravely-power_*
  • Guests
Posted September 24, 2013 - 08:34 PM
Get smaller feet.
  • Gtractor and 32spec have said thanks
#7 countryboy88 OFFLINE
countryboy88
  • 102 Thanks
  • 144 posts
Posted September 24, 2013 - 09:10 PM
Might work beter if you straped it to the inside pedal?
#8 1mathom1 OFFLINE
1mathom1
  • 210 Thanks
  • 62 posts
Posted August 13, 2014 - 10:00 AM
You are not alone.
#9 LilysDad OFFLINE
LilysDad
    Millennium Falcon
  • 13,329 Thanks
  • 9,795 posts
Posted August 13, 2014 - 12:25 PM
Wear ballet slippers
#10 MH81 ONLINE
Posted August 13, 2014 - 05:15 PM
I hear High Heels work.
#11 KennyP OFFLINE
  • 38,478 Thanks
  • 45,969 posts
Posted August 14, 2014 - 07:14 AM
Good info to know!
#12 Alc OFFLINE
  • 6,905 Thanks
  • 7,468 posts
Posted August 24, 2014 - 09:22 AM
If you adjust the left brake pedal free-play slightly less then the right ( about 3/4 to 1" difference" ) you can apply the left wheel without pushing the right  but you can still push them together as you ankle will pivot enough to get both . That's the best I could come up with mine.
#13 Glenn Ayers OFFLINE
Glenn Ayers
  • 63 Thanks
  • 86 posts
Posted December 28, 2014 - 09:15 AM
I know ... Old Thread.   New Guy too ... but I wanted to add to this thread.  I still have 3 PK's & find that using the heel of my boot on the brake pedals works the best for me.
I just found this site a couple of days ago ... seems like a good group of guys .. so I figgerd I'd join up.  Thanks for having me !
~Glenn
  • MNGB said thank you
#14 KennyP OFFLINE
  • 38,478 Thanks
  • 45,969 posts
Posted December 28, 2014 - 09:53 AM
~Glenn
:wave: Welcome to the forum! If you post in the 'Member Introductions' forum, you'll get a proper welcome for the folks here. Pics are really welcome to. A link for uploading them is in my signature!
#15 Sparky OFFLINE
Sparky
  • 1,298 Thanks
  • 1,892 posts
Posted December 28, 2014 - 10:09 AM
Aw Geez - another self revelation . My feet are 13 or 14 depending on who makes footware .  I have been turning my feet 90 degrees at times to work pedals  .
Correcting posture afterward is tedious . The things it does to the knees is not good either .
My father liked the Elec-Traks and so do I .  With them you can let the feet dangle along with other things .
