Negative Camber
6 replies to this topic
#1 Sawdust OFFLINE
Sawdust
  • 5,674 Thanks
  • 3,378 posts
Posted September 24, 2013 - 04:35 PM
I searched this topic & couldn't find anything so I'll ask. I only have two tractors a 1968 MF12 Hydro & a 1978 Cub Cadet1250 Hydro both have what looks like factory set negative camber. Both GT have solid spindles & wheels. I have seen other GT especially the MF's that look like the front wheels have zero camber ( wheels sit straight up). Is this something folks change? I like the front wheels sitting straight up & not the NC where the wheels sit inward towards the frame at the bottom. Thanks
#2 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted September 24, 2013 - 04:48 PM
The early Cub Cadet's had the wheels straight up and down. They started negative camber with the wide-frames. I like the look of it myself.My AMF 1010 has it too. Not sure how you would change it.
#3 boyscout862 ONLINE
  • 12,864 Thanks
  • 9,175 posts
Posted September 24, 2013 - 05:07 PM
The tractors generally have a king pin type system which is not adjustable. If you really wanted to change the angles you would have to make custom bushings or bend the spindles. Check that your kingpin bushings haven't gotten worn out of shape. Good Luck, Rick
#4 Canawler OFFLINE
Canawler
  • 1,948 Thanks
  • 1,802 posts
Posted September 24, 2013 - 05:11 PM
You're describing the tops of the wheels leaning out??  That's actually positive camber.
My GTX-18 has a ton of positive camber.  I agree with you.  I don't like the look of it at all and at GT speeds it really serves no purpose that I know of.
  • Sawdust said thank you
#5 Sawdust OFFLINE
Sawdust
  • 5,674 Thanks
  • 3,378 posts
Posted September 24, 2013 - 05:38 PM
Your right my bad it's positive. Thanks
#6 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,322 Thanks
  • 9,788 posts
Posted September 24, 2013 - 06:54 PM
Is it angled out because of the spindle angle or because the bushing bore is angled that way? It makes all the difference in the steering.
#7 TAHOE OFFLINE
TAHOE
  • 7,977 Thanks
  • 5,676 posts
Posted September 25, 2013 - 08:34 AM
My MF1855 is like that, the front tires should be bald it looks so bad, but they are not. They are worn evenly. I've seen pics of other 1855's and all look like that so not sure why they do that, guess there is some purpose to it.
