Unico 15
83 replies to this topic
#31 IamSherwood OFFLINE
  • 8,395 Thanks
Posted September 27, 2013 - 06:41 PM
Too bad about the gearbox Doug. Stuff happens.
Maybe you could post a picture, just in case we see one.
Edited by IamSherwood, September 27, 2013 - 06:42 PM.
#32 AverageJoe OFFLINE
AverageJoe
  • 105 Thanks
  • 143 posts
Posted September 27, 2013 - 08:55 PM
Glad to hear Daniel's 990 found a new home.  We've all drooled over that machine for years!
Too bad you're so far north, I'm downsizing a bit right now, and could probably be convinced to sell my snowthrower.
#33 DH1 ONLINE
DH1
    Electric Tractors
  • 5,433 Thanks
  • 5,618 posts
Posted September 28, 2013 - 05:14 PM
Mower Deck Pictures, she looks good with the deck mounted.
Looks like the outer bearing failed and the shaft came out.
If I put the shaft back in it meshes with the gear and when I turn it it drives the deck.
  • KennyP and SupplySergeant have said thanks
#34 IamSherwood OFFLINE
  • 8,395 Thanks
Posted September 28, 2013 - 06:07 PM
You'll have that fixed in no time Doug.
Yes, it does look good wearing the deck.
#35 MH81 OFFLINE
  • 29,979 Thanks
Posted September 28, 2013 - 06:32 PM
That's good that it didnt blow up. Is the bearing a standard one?
(Oh, and did you get the warranty when you bought it? LOL)
  • Texas Deere and Horse and KennyP have said thanks
#36 Texas Deere and Horse OFFLINE
  • 14,889 Thanks
  • 15,514 posts
Posted September 28, 2013 - 06:47 PM
I think Daniel said "3 minutes or 3 miles, whichever comes first"
:bigrofl: :bigrofl: :bigrofl:
  • DH1, MH81, KennyP and 1 other said thanks
#37 DH1 ONLINE
DH1
    Electric Tractors
  • 5,433 Thanks
  • 5,618 posts
Posted September 28, 2013 - 08:15 PM
3 POINT
After I took the mower deck off I tried out the 3 point hitch I got for it from "Texas Deere and Horse"
I only have 2 cat 0 attachments for it, Brinly 12" plow and Brinly double disc set.
Both fit and work great, tractor has no trouble at all pulling either one of them.
This is the first time since I had theses attachments that I've used both of them.
The plow needed some adjustments to work, to be expected.
The double disc set is heavy and the lift can't fully pick it up, lifts it enough that you can drive around and not tear up the lawn, but won't pick it up as high as the plow unless you help it.
There is an adjustment for the lift to increase the capacity or power it has to lift heavy stuff.
:dancingbanana: :dancingbanana: :dancingbanana:
  • olcowhand, Texas Deere and Horse, wvbuzzmaster and 4 others have said thanks
#38 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted September 28, 2013 - 08:23 PM
Looking good there Doug. You may consider adding some type of helper spring to help lift the disc?
  • DH1 and MH81 have said thanks
#39 KennyP ONLINE
  • 40,943 Thanks
  • 47,131 posts
Posted September 28, 2013 - 09:00 PM
That sounds like a good idea! Glad it's working well for you. Hope you get the mower fixed soon!
  • DH1 said thank you
#40 DH1 ONLINE
DH1
    Electric Tractors
  • 5,433 Thanks
  • 5,618 posts
Posted September 28, 2013 - 09:03 PM
I had the same problem you did with your 12" plow Kenny, didn't want to plow deep, I moved the plow pins to the same spot you did on your plow and works much better.
Edited by DH1, September 28, 2013 - 09:10 PM.
#41 MH81 OFFLINE
  • 29,979 Thanks
Posted September 28, 2013 - 09:04 PM
Wow, that looks like a great setup Doug. I think you may be falling in love with the internal combustion engine.
#42 Texas Deere and Horse OFFLINE
  • 14,889 Thanks
  • 15,514 posts
Posted September 28, 2013 - 09:08 PM
Looks good Doug, I'm glad your happy with the 3 pt.
#43 KennyP ONLINE
  • 40,943 Thanks
  • 47,131 posts
Posted September 28, 2013 - 09:10 PM
Glad you got it to plow deeper! It's fun to watch all that dirt turning over behind you!
#44 chris m OFFLINE
chris m
  • 3,341 Thanks
  • 4,065 posts
Posted September 28, 2013 - 09:24 PM
That Unico and those attachments do a great job!
What a great looking machine too! :thumbs:
#45 HowardsMF155 ONLINE
  • 2,969 Thanks
  • 3,018 posts
Posted September 28, 2013 - 09:26 PM
Very nice photos of a very nice machine with some great implements.  Get that deck fixed, you'll have a triple threat tractor!
