Log Splitter Pump
10 replies to this topic
#1 Racerxxx OFFLINE
Racerxxx
  • 57 Thanks
  • 91 posts
Posted September 23, 2013 - 05:33 PM
Not sure where to post this question.
I tow this log splitter behind my lawn tractor so I guess this is as good a place as any to ask.
Been all over the inter tubes trying to find out the specs on my log splitter pump.
Its a 1987 MTD 10 1/2 ton "split-it" model 247-642-000. Pump part number is 717-0460.
Can anybody help me find out who the manufacturer of the pump is,flow rate, single or two stage?
Thanks
  • JRJ said thank you
#2 boyscout862 ONLINE
  • 12,541 Thanks
  • 9,040 posts
Posted September 23, 2013 - 10:24 PM
Check the MTD site. Clean the pump and check for numbers. Northern Tool probably has a direct replacement pump. http://www.northernt...hydraulic-pumps  Good Luck, Rick
Edited by boyscout862, September 23, 2013 - 10:25 PM.
#3 Racerxxx OFFLINE
Racerxxx
  • 57 Thanks
  • 91 posts
Posted September 24, 2013 - 07:43 PM
20130923_173054.jpg Here is a pic.
#4 Racerxxx OFFLINE
Racerxxx
  • 57 Thanks
  • 91 posts
Posted September 25, 2013 - 06:13 PM
It has GZ stamped on one end and E58 stampmed on the end thats mounted to the engine.
#5 MH81 OFFLINE
Posted September 25, 2013 - 08:02 PM
Will either of these help?
http://service.mtdpr...ump_removal.pdf
http://service.mtdpr...gh_low_pump.pdf
#6 olcowhand ONLINE
  • 40,364 Thanks
  • 31,175 posts
Posted September 25, 2013 - 08:09 PM
Well, it is a 2 stage.
#7 Racerxxx OFFLINE
Racerxxx
  • 57 Thanks
  • 91 posts
Posted September 26, 2013 - 04:40 AM
How can you tell?
#8 skyrydr2 OFFLINE
  • 3,870 Thanks
  • 3,403 posts
Posted September 26, 2013 - 05:26 AM
How many HP is driving it? It is a 2 stage unit. Most all are sized by engine HP.
There are tons to choose from. What is your concern about the pump? Or are you thinking of buildong something with it?
#9 Racerxxx OFFLINE
Racerxxx
  • 57 Thanks
  • 91 posts
Posted September 26, 2013 - 03:50 PM
Pump is driven by a 5 hp b&s. Main concern is availability of a replacement pump to bolt up to the adaptor on the engine whenever I might need to replace it.
A couple times here recently it has just stopped while splitting. No undue noise or chatter and the fluid is good and fluid level is up and correct type. Would like to know mfg and flow rates if indeed it is a 2 stage pump. How can you tell by looking at it that its a 2 stage pump?
Thanks everybody.
#10 skyrydr2 OFFLINE
  • 3,870 Thanks
  • 3,403 posts
Posted September 26, 2013 - 06:46 PM
By all the sections and its shape and port conffiguration. The mounting is pretty standard. They do this for universitality of apps.
#11 KC9KAS ONLINE
KC9KAS
  • 5,328 Thanks
  • 4,672 posts
Posted September 26, 2013 - 07:19 PM
Maybe the spring in the by-pass valve is weak, causing fluid
Does it have a hydraulic filter? If not, maybe something floating around gets in the by-pass valve.
