Small Crawler
This topic has been archived. This means that you cannot reply to this topic.
8 replies to this topic
#1 Gtractor ONLINE
Gtractor
    G-agressive tractor
  • 9,311 Thanks
  • 4,948 posts
Posted September 23, 2013 - 09:52 AM
http://rockford.crai...4081488634.html
#2 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted September 23, 2013 - 10:25 AM
I've never seen one before and I'm wondering if the name is just a decal someone added. Someone else may recognize this crawler. It looks like it's big enough to do some work.
#3 Cvans OFFLINE
  • 6,636 Thanks
  • 6,125 posts
Posted September 23, 2013 - 10:33 AM
That is really neat.
#4 Username OFFLINE
Username
  • 2,072 Thanks
  • 1,425 posts
Posted September 23, 2013 - 10:37 AM
Looks like an Agricat that someone did a little handi work on.
#5 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted September 23, 2013 - 10:46 AM
Need to preserve this machine, looks to be well made.
01010_abrB1sx3CN4_600x450.jpg 00G0G_6a5j4Xbsz2i_600x450.jpg 00D0D_dHXuSzPuzwC_600x450.jpg
#6 glgrumpy OFFLINE
  • 8,605 Thanks
  • 7,909 posts
Posted September 23, 2013 - 12:02 PM
Tractort is Cool! Blade is homemade I bet, and no adjustments cept up/down. Looks like it is mounted at permanent angle too, unless actually bent arm?  Wonder what engine?
#7 Talntedmrgreen OFFLINE
  • 3,273 Thanks
  • 2,306 posts
Posted September 23, 2013 - 12:09 PM
It stayes that it is a 16hp, and when I look closely I can see its a Briggs single with syncro gears, so at least a 30 cube. If its a 16 as he says, its a 32 cube briggs. I can see a starter generator and briggs carb...exhaust is in the right spot too, and the gear cover is hard to deny.
#8 DougT ONLINE
DougT
    Dog Approved
  • 6,925 Thanks
  • 4,993 posts
Posted September 23, 2013 - 02:07 PM
The speed cat and the agricat were similar but 2 different machines.
#9 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted September 23, 2013 - 08:45 PM
Yes, Doug is right: http://www.smokstak....ead.php?t=72460
Ben W.
