B& S Crankshaft Difference?
4 replies to this topic
#1 KennyP ONLINE
  • 37,496 Thanks
  • 45,506 posts
Posted September 23, 2013 - 09:01 AM
I have an 18 HP horizontal (422437-1209-01) that has a broken rod. I just got a 42A707-1237-01 vertical shaft 18.5 HP. I want to use parts to fix the horizontal for the Craftsman II Steve has repainted. the crank #'s are not the same in these:
Horizontal #: 690639
Vertical#:      690636
Does anyone know what the difference is between these two cranks? Neither engine is apart right now. Just looking for info. The rods and heads are the same part #, hoping the cranks interchange.
#2 JDBrian OFFLINE
  • 9,613 Thanks
  • 14,144 posts
Posted September 23, 2013 - 10:38 AM
Kenny, would there be some difference in the vertical crank to account for thrust forces on the bearings. You may end up having to compare them side by side to identify the differences. The shaft end may be different as well.
#3 KennyP ONLINE
  • 37,496 Thanks
  • 45,506 posts
Posted September 23, 2013 - 05:03 PM
I plan to compare them when they are out, Brian. Just hoping someone has been this way before!
#4 drbish ONLINE
drbish
    Collecter
  • 1,555 Thanks
  • 1,358 posts
Posted September 23, 2013 - 05:54 PM
I could not find the exact numbers that you posted for the crank numbers.The part numbers i got were
 Crank for horizontal were 394430,394382,394394,394106.Depending on type number.Your number may supercede mine
Crank for vertical is 394028
I did find the dimensions for one of the horizontal and the vertical. 394106 and 394028
Hopes this helps
Attached File  crankshart dimensions.PDF   1.23MB   50 downloads
#5 KennyP ONLINE
  • 37,496 Thanks
  • 45,506 posts
Posted September 23, 2013 - 06:27 PM
Hopes this helps
attachicon.gifcrankshart dimensions.PDF
The #'s I gave were directly from the B&S web site, so are probably new #'s. Thanks for the PDF!
Edit: Found the difference!!!!! The vertical (394106) has a longer protrusion on the flywheel end and minute dimensional differences. Thanks!
