This Winters Project
24 replies to this topic
#16 BairleaFarm OFFLINE
BairleaFarm
  • 1366 Thanks
  • 1788 posts
Posted October 04, 2013 - 11:26 AM
Those might do the trick. I'll have to play around with it and see. I'm more of a solid mounted engine kinda guy anyways. Yeap on the deal... David massey 1650/ pile o parts owner
Sent from my SCH-I535 using Tapatalk 4
#17 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted October 04, 2013 - 07:18 PM
Have you tried your local Massey dealer for the engine mounts.
I got some for my 1450 a few years ago.
#18 BairleaFarm OFFLINE
BairleaFarm
  • 1366 Thanks
  • 1788 posts
Posted October 04, 2013 - 08:09 PM
You know I haven't. I might give them a call next week. There might be a good set on the massey I'm getting from Bobby
#19 olcowhand OFFLINE
  • 44102 Thanks
  • 32301 posts
Posted October 04, 2013 - 08:11 PM
On my Massey 1650 I repowered with a 20hp Onan, I took the rubber mounts out & replaced with solid.  Much better solid mounted I think.
  • twostep said thank you
#20 BairleaFarm OFFLINE
BairleaFarm
  • 1366 Thanks
  • 1788 posts
Posted October 04, 2013 - 08:12 PM
I prefer solid mount. In my head rubber mounts are an excuse to build and install a less balanced engine.
#21 twostep OFFLINE
twostep
    Rockstar
  • 1994 Thanks
  • 2541 posts
Posted October 04, 2013 - 11:29 PM
yeah or for those sissies that insist on having feeling in thier feet after a 2 hour mowing session.
#22 BairleaFarm OFFLINE
BairleaFarm
  • 1366 Thanks
  • 1788 posts
Posted October 05, 2013 - 06:33 AM
The numbness is suppose to be there isn't it?
#23 TUDOR OFFLINE
TUDOR
  • 573 Thanks
  • 507 posts
Posted October 10, 2013 - 04:19 AM
I hate to say it, but try JD for the mounts. They used the same ones on several GT's.
They're not cheap!
On a side note, RTV has no business anywhere near a hydraulic system! What squeezes out on the outside is of no consequence. What squeezes out on the inside could be disasterous!
Fortunately, the filter is on the suction line for hydros. For other types of systems, standard practice is to put the filter on the return line leaving the system unprotected from hazards like RTV particles that can plug the small passages of relief valves and such.
Edited by TUDOR, October 10, 2013 - 04:30 AM.
  • MH81 and BairleaFarm have said thanks
#24 BairleaFarm OFFLINE
BairleaFarm
  • 1366 Thanks
  • 1788 posts
Posted October 24, 2013 - 07:53 PM
The more and more I think about this tractor the more I think I'm going to keep it. The engine will be used to get one engine for the massey. This can be my experimental gt. The more and more I use these the more I like them. I've got that 14hp low hour engine I'm itching to use. I might take some measurements and see. I've got a spare 12hp kohler but I think it may be a hair under powered for this tractor. I dunno just brain storming aloud.
#25 TUDOR OFFLINE
TUDOR
  • 573 Thanks
  • 507 posts
Posted October 25, 2013 - 04:05 AM
In the unlikely event that the tractor can find enough traction, and with aggressive use of the drive control, the hydro has the capability to stall a 12 hp engine at WOT. It most likely won't stall a 14 hp engine, but it will be a near thing.
  • BairleaFarm and twostep have said thanks
