Project Help
6 replies to this topic
#1 Bob IN OFFLINE
Bob IN
  • 1,477 Thanks
  • 676 posts
Posted September 19, 2013 - 03:07 PM
Well I have acquired a sears tractor. Its really rough. Not much left. I would like to make something out of it. But Im not sure what. Any ideas?
  • hamman, boyscout862 and JRJ have said thanks
#2 Sawdust ONLINE
Sawdust
  • 5,653 Thanks
  • 3,367 posts
Posted September 19, 2013 - 03:46 PM
looks pretty solid from the pic. Have you figured out what your missing. Is the hood in good shape.
#3 Bob IN OFFLINE
Bob IN
  • 1,477 Thanks
  • 676 posts
Posted September 19, 2013 - 03:53 PM
The wiring system is gone. The coil is bad. The lower grill is missing. The upper grill is broken out.
#4 nbent ONLINE
nbent
    customizer
  • 673 Thanks
  • 538 posts
Posted September 19, 2013 - 10:10 PM
take the motor that is in it out find an old hit and miss engine and put in it then find/make a set of steel wheels for it
#5 boyscout862 OFFLINE
  • 12,842 Thanks
  • 9,165 posts
Posted September 20, 2013 - 04:52 AM
What do you need? You can fix it up as a dedicated tractor to whatever you need or want. Good Luck, Rick
#6 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted September 20, 2013 - 07:05 AM
I'd look for another one with the parts you need and make 1 good one out of them.
#7 MH81 OFFLINE
Posted September 20, 2013 - 07:11 AM
You said the coil is bad. Have you verified that?
Lower/upper grill is an issue, but if the engine runs, you might have fun making custom tin for it. Here was one at th last show that was re-done to look like a TO20 Ferguson Tractor.
