Case 222 Carberation Issues
7 replies to this topic
#1 John T OFFLINE
John T
  • 2 Thanks
  • 11 posts
Posted September 18, 2013 - 07:51 AM
Having some carberation issues with my Case 222.  After about 30 minutes of use the engine starts "lugging" and smoke is seen around the air filter.  When shutting down the tractor the engine runs on, even after the throttle is shut off.  Any ideas?
#2 chris m ONLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted September 18, 2013 - 11:29 AM
Have you checked to see if the air filter is clean or if the choke is open all the way yet? If it was mine, I would check those and also check the condition of the plug and points (if equipped). then go from there. Good luck.
#3 Gtractor ONLINE
Gtractor
    G-agressive tractor
  • 9,346 Thanks
  • 4,960 posts
Posted September 18, 2013 - 11:30 AM
Sounds like its getting hot.  Check the screen on the flywheel to make sure its not plugged. Also check under the cooling tins around the cylinder and make sure they are open.  When running,  make sure there is a good amount of airflow across the cylinder head.
#4 chris m ONLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted September 18, 2013 - 11:46 AM
I have a feeling you might have nailed this problem! I'm rushing around getting ready to head out, and didn't even think of that! Sure sounds like you right!
#5 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,207 Thanks
  • 5,805 posts
Posted September 18, 2013 - 02:44 PM
This would be my guess.
#6 John@Reliable OFFLINE
John@Reliable
  • 1,298 Thanks
  • 1,416 posts
Posted September 18, 2013 - 05:26 PM
Yep, dirty cooling system, or motor tins removed would be my guess too.
#7 John T OFFLINE
John T
  • 2 Thanks
  • 11 posts
Posted September 19, 2013 - 08:40 AM
Thanks to everyone who responded so quickly.  The engine cooling fins are clear and the louvers in the front of the hood are also clear so air flow is not the issue.  The air cleaner has been tapped out and blown out with compressed air but I will pick up a new one and a new spark plug this weekend.  Let you know how it turns out.
#8 John T OFFLINE
John T
  • 2 Thanks
  • 11 posts
Posted November 22, 2013 - 04:57 PM
Finally found a supplier for the proper air filter.  Put it in and it runs like a charm.  Thanks to everyone who responded with ideas.  Great job!
