Dgt 1700 -- Is This Right/original?
8 replies to this topic
#1 KBCraig OFFLINE
KBCraig
  • 55 Thanks
  • 40 posts
Posted September 17, 2013 - 10:56 PM
I spotted this on craigslist. I'm not interested, but I'm curious.
Check out that exhaust manifold -- is that original?
http://nh.craigslist...4073527935.html
  • JDBrian, boyscout862 and Dieselcubmike have said thanks
#2 Dieselcubmike OFFLINE
Dieselcubmike
  • 1343 Thanks
  • 1527 posts
Posted September 17, 2013 - 11:21 PM
Appears the manifold isn't original. Usually they are a little more curvy and don't have that big backing plate behind it
#3 nglauer OFFLINE
nglauer
  • 458 Thanks
  • 379 posts
Posted September 17, 2013 - 11:26 PM
I don't think it's original either - but that does seem like a decent deal for a Diesel. I'd love to have one of these on day.
#4 OldBuzzard OFFLINE
OldBuzzard
    Deceased
  • 7144 Thanks
  • 4825 posts
Posted September 18, 2013 - 03:47 AM
Definitely a fabbed piece. Exhaust manifolds are almost always cast.
This is what mine looks like
It's a K3D engine vs. the L3A in the 1700, but it should still be similar.
#5 JDBrian OFFLINE
  • 9666 Thanks
  • 14162 posts
Posted September 18, 2013 - 05:07 AM
Nice tractor. Looks like someone replaced a broken manifold with a custum fabricated one. I didn't know Bolens had made a diesel in that series of tractor. That's something for me to watch for locally.
#6 KBCraig OFFLINE
KBCraig
  • 55 Thanks
  • 40 posts
Posted September 18, 2013 - 05:18 AM
Thanks for the replies. I couldn't believe that welded pipe manifold could be original; even if it was, that backing plate just looked wrong.
I'm new to tractors, and I'm more interested in the older iron, but did they really use Mitsubishi 3-cyl. diesels as OEM?
If I was looking for a diesel, and if that one was closer, I might be interested. It looks like a sturdy beast. I wonder how well they start in northern New England winters.
#7 OldBuzzard OFFLINE
OldBuzzard
    Deceased
  • 7144 Thanks
  • 4825 posts
Posted September 18, 2013 - 07:22 AM
Bolens built, depending on how you want to count it, 3 or 4 diesel tractors.
The HT20D and HT22 used the Wisconsin WD2-860 2-cyl air cooled diesel.  The engine was actually built by Ducati.  Here is where the 3 or 4 comes in as they were identical, except that the HT20D was for the US, and the HT22 was for export. What is interesting is that even with the same engine, the HT20D is listed as having 19.9 hp. and the HT22 as having 22 hp.
The HDT1000, which was supposed to be for export only used the water cooled Mitsubishi K3D-61FG engine, rated at 22 Hp.
Those 3 models were all based off of the HT23.  The HT20D and HT22 were based on the 2389, and the HDT1000 was based on the 2389s which had the power steering, cruise control and aux hydro cooler as standard equipment.
The DGT1700 had the water cooled Mitsubishi L3A-61BG engine rated at 17 hp.
All of the other 'Bolens' diesels were built by Iseki, and had a mix of Iseki, Mitsubishi, and Isuzu engines.
  • Newpaws493 and KBCraig have said thanks
#8 JD DANNELS OFFLINE
JD DANNELS
  • 3790 Thanks
  • 3907 posts
Posted September 18, 2013 - 10:12 AM
I agree that that was fabbed. I have not seen a Factory exhaust manifold like that since Dad Junked his 51 Nash.
Edited by JD DANNELS, September 18, 2013 - 10:13 AM.
#9 Utah Smitty OFFLINE
Utah Smitty
  • 2303 Thanks
  • 2002 posts
Posted January 08, 2014 - 12:52 AM
This is a late reply, but I just came across the parts manual for the DGT1700--the manifold in the parts manual looks just like the one in the picture--a heavy plate with a tube-like collector... it may be original.
I'll upload the manual for it as soon as I run an OCR on it so you can search the text in it.
Smitty
