Turning Big Tools Into Small Ones
14 replies to this topic
#1 freedhardwoods OFFLINE
freedhardwoods
  • 374 Thanks
  • 197 posts
Posted September 17, 2013 - 07:21 PM
I debated wether to start this thread now or not because it will probably be several weeks before I get it all done.
I grew up on a small farm and have worked on large farms. I have used tractors from 10 to 400 hp and pulled all types and sizes of equipment behind them.
I was wanting some tough, heavy duty implements to pull with my Case 446 in my garden and I didn't want to spend a lot so I decided to make my own.
I found and bought a 6' drag disc about 60 miles away thinking an offset disc made with 2 of the gangs would cut out the tracks of my tractor. When I got it home I found out it wasn't going to be quite big enough. So much for my accurate eyeballs. :mad2:
As I was disassembling it, I knew I could cut the 4 axles and weld together 2 the right length, but wasn't looking forward to the extra work.
Two days later I found another drag disc 40 miles away that was the exact same brand and model and was 8' wide. :dancingbanana:  I bought it, got it disassembled, cleaned 2 of the bearings, matched the blades, and got one gang all put together except for needing some new springs on the scrapers.
I found a 10' field cultivator 70 miles away about the same time I found the discs and finally called about it and bought it. That was a bigger chore taking it apart than both discs because of all the 1/2" solid rivets holding things together.
My goal is to build a disc, hiller, field cultivator, row cultivator, ripper/subsoiler, middlebuster, and make a few extra tools to sell to make back part of the money spent on the 3 original tools.
  • MH81, hamman, JDBrian and 1 other said thanks
#2 KennyP ONLINE
  • 41,525 Thanks
  • 47,427 posts
Posted September 17, 2013 - 07:25 PM
Sounds like you have it figured out. At least these will be strong enough to handle it!
#3 JDBrian OFFLINE
  • 9,655 Thanks
  • 14,162 posts
Posted September 17, 2013 - 07:28 PM
Welcome to GTTalk. That looks like a very ambitious project. Thanks for the pictures and we would really appreciate seeing some photos of the conversion process.
#4 MH81 OFFLINE
  • 29,979 Thanks
Posted September 17, 2013 - 07:47 PM
Ooooo... Another cool build thread in the making. :thumbs:
Looking forward to it.
#5 shorty ONLINE
shorty
  • 5,922 Thanks
  • 5,453 posts
Posted September 17, 2013 - 08:18 PM
Welcome to GTtalk! That is sounding like a fun project.  :thumbs:
#6 UncleWillie ONLINE
  • 16,426 Thanks
  • 9,039 posts
Posted September 17, 2013 - 08:20 PM
Neat idea/
#7 boyscout862 ONLINE
  • 13,693 Thanks
  • 9,476 posts
Posted September 17, 2013 - 11:52 PM
Welcome to GTT. Nice to see another person that builds their own. Good Luck, Rick
#8 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 14,336 Thanks
  • 10,295 posts
Posted September 18, 2013 - 06:19 AM
Another smart, ambitious member to make the rest of us look bad! Welcome!!!
#9 TAHOE ONLINE
TAHOE
  • 8,339 Thanks
  • 5,820 posts
Posted September 18, 2013 - 08:27 AM
Welcome!!!
If were close enough I had known you were looking, I have a 6' or maybe wider set of disc I may scrap, you could've used for parts. Frame is broken on it. I had thought of cutting it up and making me some implements out of it for my tractors
#10 freedhardwoods OFFLINE
freedhardwoods
  • 374 Thanks
  • 197 posts
Posted September 18, 2013 - 07:20 PM
Welcome!!!
Thanks for the offer. I should be set pretty good with what I have now. Also, I think there might be some distance between us. I'm about 30 miles from Illinois.
Thanks to everyone else for the comments.
I couldn't find this picture earlier. This gang has 17" blades and weighs 180 pounds already without the 3 pt hitch. The hitch will probably add another 20 or 30 pounds. Because of this, I've pretty much decided to just make it a one gang disc. Since a disc is a packing tool (it cuts by exerting down pressure which compacts the subsoil), I only plan on using it to cut cornstalks and sod. I will use the field cultivator for general tillage.Optimized-G.jpg
Edited by freedhardwoods, September 18, 2013 - 07:29 PM.
#11 freedhardwoods OFFLINE
freedhardwoods
  • 374 Thanks
  • 197 posts
Posted September 20, 2013 - 07:02 PM
I got my disc hitch done today. Here's some pic's of the build.
AA.jpg BB.jpg CC.jpg DD.jpg EE.jpg FF.jpg GG.jpg HH.jpg II.jpg QQ.jpg RR.jpg KK.jpg
  • Alc, boyscout862 and Newpaws493 have said thanks
#12 freedhardwoods OFFLINE
freedhardwoods
  • 374 Thanks
  • 197 posts
Posted September 20, 2013 - 07:08 PM
I needed some weight on the front end so I dug through my parts and and added about 120 pounds.
  • Alc and Newpaws493 have said thanks
#13 freedhardwoods OFFLINE
freedhardwoods
  • 374 Thanks
  • 197 posts
Posted September 20, 2013 - 07:22 PM
I couldn't do this again in a hundred years. I cut one of the braces from a piece of flat stock freehand, with no markings of any kind. After I cleaned them up on the grinder, this is what I had; A PERFECT MATCH.
#14 freedhardwoods OFFLINE
freedhardwoods
  • 374 Thanks
  • 197 posts
Posted September 23, 2013 - 05:45 PM
Next tool build on my list is here - http://gardentractor...ltivator-build/
#15 KennyP ONLINE
  • 41,525 Thanks
  • 47,427 posts
Posted September 23, 2013 - 06:05 PM
Looks good! Glad you added front weight, as I was sure you would need some!
  • freedhardwoods said thank you
