Vote for Tractor of the Month
Snapper 1650 Hi Gear Issue :(
4 replies to this topic
#1 Many944s OFFLINE
Many944s
  • 3 Thanks
  • 5 posts
Posted September 17, 2013 - 03:15 PM
Well, I have finally sorted out all the wiring issues on the cab and topped off my trans oil. HOWEVER, the tracter goes nowhere in "hi" gear? It goes forward and back just fine in "low", just not when "hi"gear is engaged. I have checked to make sure it isnt in neutral, as it wont roll when trying to push it, the trans is defenitely engaged... Any ides?
#2 Many944s OFFLINE
Many944s
  • 3 Thanks
  • 5 posts
Posted September 17, 2013 - 03:17 PM
P.S. the hyd. Lift piston works fine on the snowblower unit as well, if that helps in diag.
#3 Many944s OFFLINE
Many944s
  • 3 Thanks
  • 5 posts
Posted September 18, 2013 - 12:39 PM
Noone?? Any ideas??
#4 HDWildBill OFFLINE
  • 8,842 Thanks
  • 8,615 posts
Posted September 18, 2013 - 12:45 PM
Wish I could help but I'm not familiar with Snappers. One suggestion is my Craftsman has a Hi & Low and I know that when I move it from low to hi sometimes it doesn't quite go in and I have to work it a bit using the clutch,
#5 coldone OFFLINE
coldone
  • 1,634 Thanks
  • 1,671 posts
Posted September 18, 2013 - 05:26 PM
Some of the snappers have a mechanical stop/plunger that prevents the shifter from moving between hi and low. If yours has this, there should be a cable that connects the brake peddle to the plunger on the stop. The peddle must be pushed all the way down and then shift the hi/lo shifter. If the cable is broken, pushing the peddle will not pull the plunger out of the way
  • HDWildBill said thank you
