Snapper 1650 Hyd. Fluid Help.
5 replies to this topic
#1 Many944s OFFLINE
Many944s
  • 3 Thanks
  • 5 posts
Posted September 16, 2013 - 01:39 PM
This is my first post to the forum. I have searched for alot of info here that has helped TREMENDOUSLY!
I recently picked up a 1650 with cab and snowblower for next to nothing (under $200). After rebuilding the carb and freeing up the blasted brake pedal, its running great! However, I am trying to figure out the proper method for checking the trans oil level. There is a slight leak (1 drop every couple of hours) at the mid hyd. Piston, which I will address soon. Should the fluid level (dipstick under seat) be checked with the engine running in neutral, or with the engine off?
Thank-you in advance,
Nick
  • tinbender7, boyscout862 and Dieselcubmike have said thanks
#2 DougT ONLINE
DougT
    Dog Approved
  • 6,925 Thanks
  • 4,993 posts
Posted September 16, 2013 - 02:01 PM
Nick, Welcome to the forum. I don't have the answer to your question but I'm sure there will be someone come along that knows shortly.
#3 olcowhand ONLINE
  • 41,076 Thanks
  • 31,393 posts
Posted September 16, 2013 - 02:10 PM
Engine off is best, but likely be ok with it running as well.  Don't think enough circulation at idle in neutral to stir the level much if at all.
#4 boyscout862 ONLINE
  • 12,834 Thanks
  • 9,160 posts
Posted September 16, 2013 - 03:02 PM
Welcome to GTT. You can down load the manual from the manuals section. Good Luck, Rick
#5 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,335 Thanks
  • 1,520 posts
Posted September 16, 2013 - 05:55 PM
Hello there and welcome! :wave:
#6 Newpaws493 OFFLINE
Newpaws493
  • 1,366 Thanks
  • 1,810 posts
Posted September 16, 2013 - 09:33 PM
:welcometogttalk:
