* * * * * 2 votes
The Ask For Manuals Thread.
309 replies to this topic
#181 Gabriel OFFLINE
Gabriel
  • 1,442 Thanks
  • 1,859 posts
Posted April 02, 2014 - 09:37 AM
here you'll find it (if it helps)
Thanks, though I was looking for the service manual.
#182 jd.rasentrac ONLINE
jd.rasentrac
  • 4,773 Thanks
  • 4,265 posts
Posted April 02, 2014 - 11:42 AM
what are you looking for, Gabriel? wiring or something else?
  • Gabriel said thank you
#183 Gabriel OFFLINE
Gabriel
  • 1,442 Thanks
  • 1,859 posts
Posted April 02, 2014 - 11:54 AM
I'm mainly looking for info on changing the transmission fluid.
#184 jd.rasentrac ONLINE
jd.rasentrac
  • 4,773 Thanks
  • 4,265 posts
Posted April 02, 2014 - 11:57 AM
okay, this is what JD says, sorry I can't help:
Service Transmission Checking Transmission
The transmission is a sealed component. No maintenance is required on this transmission. If you suspect any transmission problems, please contact your John Deere dealer.
#185 Gabriel OFFLINE
Gabriel
  • 1,442 Thanks
  • 1,859 posts
Posted April 02, 2014 - 01:39 PM
Thanks, I've read that in the owners manual. The transmission seems fine, but from what I've read, it can be good to change the fluid, even in a "sealed" transmission. It's 13 years old this year, so I think it would be good to change the fluid. I read about (not on this forum), and saw pictures, of how one person did it and had good success.
#186 jd.rasentrac ONLINE
jd.rasentrac
  • 4,773 Thanks
  • 4,265 posts
Posted April 03, 2014 - 01:48 AM
Here's the transmission, but I don't know the fuel capacityMP24610________UN27MAR01.gif
#187 Gabriel OFFLINE
Gabriel
  • 1,442 Thanks
  • 1,859 posts
Posted April 03, 2014 - 10:00 AM
From what I've seen and read, you have to drop the trans. out of the frame, remove a cap on top, flip the trans. over, and drain the fluid. Then, you refill it through the same opening that you drained the old fluid out of.
Edited by Gabriel, April 03, 2014 - 10:02 AM.
#188 iZach98 OFFLINE
iZach98
  • 157 Thanks
  • 155 posts
Posted April 23, 2014 - 09:11 AM
I am in need of a manual for a Wheel Horse a-100 here is a pic of the id number for ya
#72-10BP0-4103
1016
#189 MH81 OFFLINE
Posted April 26, 2014 - 07:52 AM
I am in need of a manual for a Wheel Horse a-100 here is a pic of the id number for ya attachicon.gifImageUploadedByTapatalk1398262277.460839.jpg
Can't quite read the model number. Can you type it out and post that?
#190 Gabriel OFFLINE
Gabriel
  • 1,442 Thanks
  • 1,859 posts
Posted April 26, 2014 - 09:16 AM
#72-10BP0-4103
1016
This place has on for sale: http://www.mowergrav...s-a90-a100-p...
  • iZach98 said thank you
#191 iZach98 OFFLINE
iZach98
  • 157 Thanks
  • 155 posts
Posted April 26, 2014 - 09:39 AM
Thanks Gabriel :)
#192 MH81 OFFLINE
Posted April 26, 2014 - 10:15 AM
I was looking for one, but I can't read the model number from the pic.
Sometimes, there is stuff at the mfg website in the customer support area
http://www.toro.com/...artslookup.aspx
  • Gabriel and iZach98 have said thanks
#193 Gabriel OFFLINE
Gabriel
  • 1,442 Thanks
  • 1,859 posts
Posted April 26, 2014 - 10:50 AM
Not to make you feel bad, but Zach typed out the numbers above the picture of the number plate.
#194 Cat385B ONLINE
    HAZMAT CAT
  • 13,974 Thanks
  • 10,002 posts
Posted April 26, 2014 - 02:30 PM
Actually, I did that and added it to Zach's post. Mostly to mess with Alan.
  • MH81, Gabriel and iZach98 have said thanks
#195 kershawa OFFLINE
kershawa
  • 1 Thanks
  • 3 posts
Posted April 28, 2014 - 12:30 AM
Can't seem to find a manual for a John Deere 110 in your manuals section..
Type: T0633
S/N 249285M
Kohler Engine
Model: K241AS
Scec: 46678d
S/N: 5071414
I am specifically looking for a wire schematic, most of the harness is still in tact but there are a couple wires (purple/white, pink, and light green, that had pulled out of different connectors and need to just find their home again.
Thanks.
