Mf Mower Deck Timing Pulleys
21 replies to this topic
#16 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted September 24, 2013 - 05:44 AM
Here are a couple of a deck I sold in the spring.
#17 TAHOE OFFLINE
TAHOE
  • 8514 Thanks
  • 5931 posts
Posted October 01, 2013 - 09:30 AM
Guys, I was looking through an industrial mag we get here at work, this company was advertising in the back. If someone wants to do some research, this maybe a possible company to get these deck parts from. Not sure if they carry belts that would work, but the pulleys maybe promising. Who knows, send them some pulleys and belts, they maybe able to make something.
http://www.brecoflex...dex.php?CATID=1
  • ducky and MH81 have said thanks
#18 cchap45 OFFLINE
cchap45
  • 104 Thanks
  • 83 posts
Posted October 02, 2013 - 12:03 PM
unless they are unique, you should just neet to know the pitch, belt width, bore and #of teeth and should be able to order standard timing belt pullies.  Has anyone checked McMaster Carr, Reid tool supply or Carr Lane?
#19 Texas Deere and Horse OFFLINE
  • 15111 Thanks
  • 15570 posts
Posted October 02, 2013 - 12:10 PM
You can find the pulleys, the problem is getting the spline right in the center. I have been doing some research on these for a good while. I can get them made, but they are too expensive to use or sell.
  • ducky said thank you
#20 cchap45 OFFLINE
cchap45
  • 104 Thanks
  • 83 posts
Posted October 02, 2013 - 02:12 PM
I see.  I will be heading down this road this winter as I just picked up a 1650 and plan on going through the deck this winter.
In the past I have "cheated" on some splines several ways.  I have wire burned the female spline, that got a bit expensive. Or we had a broach made by the same method, again that was expensive. The cheap way was to make a broach out of an old shaft, that worked ok in soft material.  Not perfect but cheaper than having a run at the local gear company.
Any thought about reproducing or modifying the shaft to match up with an available pully?
#21 ducky ONLINE
  • 2326 Thanks
  • 4310 posts
Posted October 05, 2013 - 07:45 PM
What I have found is that the 41 tooth sprocket that Massey used is not a standard configuration.  I was able to have a shop make that 41 tooth stock and plan on making these to replace any worn pulleys.  That way all exsisting parts will still work with the new pulleys.  I am going to broach the internal spline to fit the exsistiing blade shafts.  I do not have a solid # but I do feel these will be quite reasonabley priced.  The first run of pulley stock had a flaw in the base matterial and they are running it again so I am still waiting on some of the parts to make this all come together.
We are in the height of Poo hauling and chopping corn silage up here right now so bear with me till we can get all the parts together to make this happen.
  • olcowhand, Alc, Texas Deere and Horse and 2 others have said thanks
#22 ENafziger OFFLINE
ENafziger
  • 261 Thanks
  • 254 posts
Posted October 07, 2013 - 08:31 AM
^^^ That'd be great!!!  No hurry here...I plan on keeping my deck forever, so anytime in the next 40 years or so will be fine! :D
