8 Hp Briggs Problem
7 replies to this topic
#1 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted September 13, 2013 - 09:09 PM
well fist of all i have a speedex s-19 with 8 hp briggs. it was leaking oil from behind the flywheel, so i figured the seal was bad. i changed the seal it was still leaking oil so i finally founnd a crack between the crank and directly behind the stater.
I got it all fixed up and now i am shearing flywheel keys and it jumps off time. why why why??? its driving me nuts.
is the flywheel not torqued right? is there oil in there? i dont know it seem the everytime i shut it off it does it. please give me some ideas??????
#2 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted September 13, 2013 - 09:26 PM
Tell me about the ignition. Is it magneto or solid state?  I'm wondering if the engine is backfiring while you are shutting it down.  Is the kill switch good?
Your flywheel is not torqued right.  Is this engine recoil start?  Is this the original engine?
Ben W.
#3 MH81 OFFLINE
Posted September 13, 2013 - 09:33 PM
Is there any clunking if you turn it over by hand with the plug out? Major wear or slop in the flywheel area?
#4 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted September 13, 2013 - 10:18 PM
no major slop and theres a magnetron or electronic ignition on it  and no it runs fine but i flip the switch and i just wont start then and btw this engine was completly redone in the fall last year and has been to a couple plow days best running 8hp i got
#5 MH81 OFFLINE
Posted September 14, 2013 - 06:45 AM
What kind of ignition? I didn't understand that.
#6 boyscout862 OFFLINE
  • 13,430 Thanks
  • 9,379 posts
Posted September 14, 2013 - 07:30 AM
Check that the key ways are tight. Check the fit of the flywheel to the crank taper. Wash the crank taper and flywheel hole. When putting it together besure that you have the proper concave washer on the crankshaft and the torque is right. If none of this works, I suspect that something is stopping the crank violently. What caused the crack in the block? Good Luck, Rick
#7 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted September 14, 2013 - 09:22 AM
I dont know why the block cracked because it just started leaking oil one day and i assumed it was the seals the ignition is just a step above points its and electronic ignition
this is basically the same one i got http://www.ebay.com/...=item43bf81c701
#8 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted October 17, 2013 - 09:52 PM
well i havent got my briggs welded up yet but did manage to find a 16 hp v twin vanguard briggs to repower it got it for a reeeaaalllll good price
