Need Some Help Guys
27 replies to this topic
#16 boyscout862 ONLINE
  • 12,834 Thanks
  • 9,160 posts
Posted September 13, 2013 - 07:43 PM
Is there any of the other Kohler rods that will fit with a little modification? Back in the 60s. a friend fixed his 1923 Mity Cat with pistons from a Simca auto. I was thinking of a K301 rod with the dipper machined off or something like that. I am watching this with great interest because I have an HT23 that I plan to rebuild next year. Good Luck, Rick
#17 EricFromPa ONLINE
EricFromPa
  • 3,649 Thanks
  • 3,109 posts
Posted September 13, 2013 - 07:51 PM
WOW $195 + shipping
http://www.ebay.com/...=item58a43dec03
These guys have 48 067 13s rods for $140 each.Will they work with your pistons?
http://www.superxpow...CATALOGS|~27851
Edited by EricFromPa, September 13, 2013 - 07:59 PM.
#18 bhts OFFLINE
bhts
  • 1,472 Thanks
  • 2,165 posts
Posted September 13, 2013 - 08:08 PM
I did try the rods from a different motor and all were to long and could not be machined to fit.
WOW $195 + shipping
I seen the ebay ones and will not go that route as that would put the parts cost close to $1200.00 alone. As for the the other place they don't have them.
  • Texas Deere and Horse and boyscout862 have said thanks
#19 EricFromPa ONLINE
EricFromPa
  • 3,649 Thanks
  • 3,109 posts
Posted September 13, 2013 - 08:20 PM
You might have to get a set of used rods and have Millers machine them for bearing inserts.He charges $25 labor for each rod grind and $17.50 for a pair of his best inserts.
http://gardentractor...om/a1engine.htm
My uncle is also looking for a set of K582 rods for his Super Cub.He stopped running it before it broke but it chatters pretty bad.He's pondering on a new Kohler CH750 30hp repower if he can't find rebuild parts reasonable.
He has a Cub 1872 repowered with a 23hp kohler.It had a blown KT series 1 18hp engine in it when he got it.He bought the K582 used and ran it in the cub for a long time.
Mowing grass with a big deck kills a worn out engine pretty quickly lol.
Edited by EricFromPa, September 13, 2013 - 08:37 PM.
#20 OldBuzzard ONLINE
OldBuzzard
  • 7,019 Thanks
  • 4,791 posts
Posted September 13, 2013 - 10:38 PM
Looks like you can get them here.
http://www.kohlerpar...2-131101A/rod/1
I got to the check out after I selected the ones that are $109.70 each.
  • MH81, bhts and boyscout862 have said thanks
#21 HDWildBill OFFLINE
  • 8,975 Thanks
Posted September 14, 2013 - 09:09 AM
Sorry Bob but no go with our local shop.  :(
  • bhts said thank you
#22 Texas Deere and Horse OFFLINE
  • 14,800 Thanks
  • 15,495 posts
Posted September 14, 2013 - 10:19 PM
Bob, I didn't have any luck at my local places. I'm thinking inserts are the way to go on this one..
#23 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,287 Thanks
  • 9,774 posts
Posted September 15, 2013 - 05:32 AM
Have Stens quit making them also?
#24 bhts OFFLINE
bhts
  • 1,472 Thanks
  • 2,165 posts
Posted September 16, 2013 - 06:17 PM
These were never made aftermarket from my info.
#25 bhts OFFLINE
bhts
  • 1,472 Thanks
  • 2,165 posts
Posted September 16, 2013 - 06:20 PM
Thanks for all the help guys.
  • HDWildBill said thank you
#26 101 senior ONLINE
101 senior
  • 244 Thanks
  • 373 posts
Posted September 17, 2013 - 01:19 AM
Just a thought. Can Brian Miller fab one?
#27 Utah Smitty OFFLINE
Utah Smitty
  • 1,701 Thanks
  • 1,781 posts
Posted September 17, 2013 - 03:32 AM
My father in law just got a Bolens HT23 with a bad motor. It is a Kohler K582.Just ordered all new parts to rebuild the motor and find out the next day rods are NLA. I am looking for a set of  .010 under as the crank needs turned because the oil pump went out. The part number for the rod is a 48 067 17 and I need two. I have tried all my sources and no luck so if any one has a old shop close two them and would check and see if they have a set sitting that would be great.
If the crank will clean up less than .010" under, don't grind it to .010"  A good machinist can take a set of standard rods and make them fit a slightly undersized journal.  This saves you buying new rods, plus you get more life out of your crank.
I had this done on a K341 Kohler... I bought a used crank to replace the one that was in pieces in the crankcase... the journals were smooth, but also a couple thou undersize.  A local engine rebuilder ground the crank just enough to make sure the journals weren't lopsides, and fit a standard conn rod to it...
Regards,
Smitty
#28 Utah Smitty OFFLINE
Utah Smitty
  • 1,701 Thanks
  • 1,781 posts
Posted September 17, 2013 - 03:41 AM
Another thought... the K482 uses the same pistons, AND, IIRC, the same rods as the K241... I wonder if K301 rods would work on your 582???... just checked it out... the K301 has a different stroke than the 582, so I assume the rods are different.
Smitty
