Need Some Help Guys
27 replies to this topic
#1 bhts OFFLINE
bhts
  • 1,416 Thanks
  • 2,119 posts
Posted September 13, 2013 - 03:02 PM
My father in law just got a Bolens HT23 with a bad motor. It is a Kohler K582.Just ordered all new parts to rebuild the motor and find out the next day rods are NLA. I am looking for a set of  .010 under as the crank needs turned because the oil pump went out. The part number for the rod is a 48 067 17 and I need two. I have tried all my sources and no luck so if any one has a old shop close two them and would check and see if they have a set sitting that would be great.
Edited by bhts, September 13, 2013 - 03:06 PM.
  • boyscout862 and JRJ have said thanks
#2 boyscout862 OFFLINE
  • 10,037 Thanks
  • 7,669 posts
Posted September 13, 2013 - 03:15 PM
Check with our sponsors, Sams Bolens, and NAPA. If these don't pan out, try your local shops. There may be a set sitting on a shelf that was ordered but not picked up. That is a good tractor. Good Luck, Rick
#3 olcowhand OFFLINE
  • 36,194 Thanks
  • 29,975 posts
Posted September 13, 2013 - 03:23 PM
You might be able to have std rods machined for inserts to go undersize.
#4 HDWildBill OFFLINE
  • 8,836 Thanks
  • 8,613 posts
Posted September 13, 2013 - 04:02 PM
I'll call my local shop tomorrow and see if they have any.
  • bhts said thank you
#5 MH81 ONLINE
  • 27,987 Thanks
  • 28,943 posts
Posted September 13, 2013 - 04:21 PM
I too, will call the local small engine guy and see.
Sorry about the luck Bob
#6 bhts OFFLINE
bhts
  • 1,416 Thanks
  • 2,119 posts
Posted September 13, 2013 - 04:22 PM
That was my next option but standard rods are NLA also
#7 MH81 ONLINE
  • 27,987 Thanks
  • 28,943 posts
Posted September 13, 2013 - 04:23 PM
? :wtf: ?  It was always my assumption that Kohler stuff was still around because they are... Is this an oddball engine or are they abandoning parts for these all together?
#8 OldBuzzard OFFLINE
OldBuzzard
  • 6,573 Thanks
  • 4,651 posts
Posted September 13, 2013 - 05:05 PM
Maybe this?
http://www.ebay.com/...=item3f2953f0f6
And the crank as well from the same guy/engine.
http://www.ebay.com/itm/380717439001
#9 Bolens 1000 OFFLINE
  • 12,924 Thanks
  • 17,297 posts
Posted September 13, 2013 - 05:06 PM
Maybe this?
I think he's looking for new Rods.... Dont think I'd want to be using a used rod in a freshly rebuilt engine......
#10 OldBuzzard OFFLINE
OldBuzzard
  • 6,573 Thanks
  • 4,651 posts
Posted September 13, 2013 - 05:20 PM
True, but if all else fails.....
#11 olcowhand OFFLINE
  • 36,194 Thanks
  • 29,975 posts
Posted September 13, 2013 - 05:44 PM
I've never bought a new rod for any Onan I've repaired.  I always buy good used ones.  In the case of needing an undersized insert machined to fit, a used one, even scuffed will work fine.  It's gonna be machined out anyway.
#12 bhts OFFLINE
bhts
  • 1,416 Thanks
  • 2,119 posts
Posted September 13, 2013 - 06:09 PM
Nope not a oddball motor was built for 25 plus years. Kohler has been phasing these out for sometime now along with all the twin k-series engines. Want be long until no parts can be gotten for them.
#13 bhts OFFLINE
bhts
  • 1,416 Thanks
  • 2,119 posts
Posted September 13, 2013 - 06:21 PM
Guys made a mistake on the number it is 48 067 13 just two many numbers to remember
#14 KennyP OFFLINE
  • 29,459 Thanks
  • 40,433 posts
Posted September 13, 2013 - 06:26 PM
I hope someone can get what you need!
#15 superaben OFFLINE
superaben
  • 7,665 Thanks
  • 5,677 posts
Posted September 13, 2013 - 07:43 PM
No luck here, Bob.
Ben W.
