Cross Reference For Jd Hydraulic Connectors?
jd 420 hydraulic quick connect am37982
6 replies to this topic
#1 Utah Smitty OFFLINE
Utah Smitty
  • 1,713 Thanks
  • 1,793 posts
Posted September 13, 2013 - 08:55 AM
The front hydraulic connectors for my JD420 leak badly when I hook up the Front End Loader, even when there's no pressure to them. They don't leak when it isn't connected.  I suspect the seals are bad in the female connectors on the tractor.
I'm a total newbie when it comes to identifying hydraulic connectors. Can these be rebuilt? If not, is there an industry cross reference to the JD part?  The JD number is AM37982. They're available at the JD store, but pricey.
Thanks for any information you can provide.
Thanks,
Smitty
#2 jd.rasentrac ONLINE
jd.rasentrac
  • 4,809 Thanks
  • 4,305 posts
Posted September 13, 2013 - 10:24 AM
Hello Smitty,
I'm no friend of epay, but they have connectors please click here I don't know, if they are expensive or not. The european prices are different to the american.
If these are the connectors you're looking for  jd connect.jpg   then there must be cross references.
  • Utah Smitty said thank you
#3 Trav1s ONLINE
Trav1s
  • 3,582 Thanks
  • 4,558 posts
Posted September 13, 2013 - 10:44 AM
Those are regular pioneer fittings and I got them at the local Napa.  I don't recall the price or part number.
#4 Utah Smitty OFFLINE
Utah Smitty
  • 1,713 Thanks
  • 1,793 posts
Posted September 13, 2013 - 10:51 AM
What size are the fittings--1/4"
#5 Trav1s ONLINE
Trav1s
  • 3,582 Thanks
  • 4,558 posts
Posted September 13, 2013 - 11:28 AM
I will see if I can find the boxes
#6 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted September 13, 2013 - 05:11 PM
Smitty, there is an o ring in the female end of the fitting that is the only replaceable seal. The connectors could be corroded which prevents a good seal with the tip of the male quick connect. Have a good look at the inside and see if it's clean and smooth where it needs to seal to the male tip. The O rings are a standard size 113 at least for my 317 which most likely has the same couplers. JD part no 32246 for the o ring. Any hydraulic supplier should have those.
  • Alc and Utah Smitty have said thanks
#7 Utah Smitty OFFLINE
Utah Smitty
  • 1,713 Thanks
  • 1,793 posts
Posted September 13, 2013 - 06:43 PM
Thanks, everyone, I'll check it out... I'm tired of my tractor bleeding all over the driveway.
Smitty
Also tagged with one or more of these keywords: jd 420, hydraulic quick connect, am37982
