Ww Grinder I Got
18 replies to this topic
#1 lyall OFFLINE
lyall
  • 1,807 Thanks
  • 1,428 posts
Posted September 12, 2013 - 10:27 PM
Just got a WW Grinder Model 250 Renegade  today
been looking for a good chipper for a while
found it on Craigslist and wrote down the guys number - than lost it
he posted in in July
I checked Craigslist list week for it and it was gone
found his number and call him and he said that he still had it - so I told him I would like it and need to look at it got it chearer than he had it listed for
got it started and the B&S 8 hp sound great
It is a great condition for being brought back it 1996 new
got all the manual and parts books and the orrginal bill of sell
it looks like it was not used to much
I was needing a chipper - I have an old WW Grinder Model 62 with shoot that I got back in the 90's
It has worked great all the years for me and hope it will for many more, but it is very heavy and hard to move around
I use it a lot to mix the compost and to loose the compost up
the Renegade is so much earier to move around
I hope it last me a long time - which it should
I also had an old Bolen shredder that the motor went bad (still have the unit but no motor) it was great to use - and found a Atlas shredder that works great for leaves - but not when they are wet
will put it to use in the morning got a pile of branches to chip up
but first I had to check it over and make some rods for it so went I remove the screen and want to mix wet compost I have them ready
oh my compost pile is 5x5x16 feet
and I am getting all the sheep manure I want and need for free - just how to haul it and he loads it for me for free -  just a mile away from me
  • Alc, JD DANNELS, LilysDad and 2 others have said thanks
#2 JDBrian OFFLINE
  • 9,592 Thanks
Posted September 13, 2013 - 05:57 AM
Nice looking machine. The engine looks like the older style commercial Band S. Reliable engines IME.
  • lyall said thank you
#3 MH81 ONLINE
  • 28,371 Thanks
  • 29,098 posts
Posted September 13, 2013 - 07:03 AM
Good you found the number.
Nice looking chipper.
#4 lyall OFFLINE
lyall
  • 1,807 Thanks
  • 1,428 posts
Posted September 13, 2013 - 12:42 PM
checked and cleaned it over this morning
it is in very good shape - very little paint ware
it looks like they hardly used it
changed the oil and checked the plug - plug looked good
oh he also gave me a 2 gallon gas can over half full of gas
now to chip up some branches later today
have to help put on a metal roof on a garage for a friend that I am getting all the sheep manure from
Edited by lyall, September 13, 2013 - 08:52 PM.
#5 lyall OFFLINE
lyall
  • 1,807 Thanks
  • 1,428 posts
Posted September 13, 2013 - 08:58 PM
got some branches round up and started chipping
chipper for around a half hour
it sure did a great job chipping up branches from the Apple trees
some die old branches and most branches I cut off the apples tree because they broke because of the weight of the apples
going the put the chips around some brushes
chipping and shredding thru the 3/4" screen sure make great mulch
#6 shorty ONLINE
shorty
  • 4,076 Thanks
  • 4,347 posts
Posted September 14, 2013 - 06:09 AM
Nice looking chipper. That will be handy for the fall cleanup.
#7 amurfey OFFLINE
amurfey
  • 1 posts
Posted February 22, 2014 - 11:35 AM
Have you had to sharpen the blade(s) on this unit?  I have the same model, it has a tough time shredding even small branches. Do you know if the blade easily accessible for sharpening?
Thanks
#8 lyall OFFLINE
lyall
  • 1,807 Thanks
  • 1,428 posts
Posted March 01, 2014 - 09:02 PM
the unit had little usage
the blade is still sharp
but when it does need the be re-sharpen, these is a machinist it town that can sharpen it - cheap
#9 murwood OFFLINE
murwood
  • 2 posts
Posted May 05, 2014 - 07:56 PM
Hi there,
I have the #47015 model chipper, got it for free as the motor was blown. Put a 1 1/2 HP 220 V motor on it.
I have taken the blade out once.
It was a bear.....
Does anybody have an owners manual? There has to be an easier way than what I did.
#10 lyall OFFLINE
lyall
  • 1,807 Thanks
  • 1,428 posts
Posted May 06, 2014 - 08:35 PM
Hi there,
It was a bear.....
Hi murwood
first welcome to forums
who made your chipper?
if you can post a picture of it would help other find you a manual
there are several manual in the manual section on this site
it might be there
#11 murwood OFFLINE
murwood
  • 2 posts
Posted May 08, 2014 - 11:31 AM
It is a W W Grinder model #47015.
I need to pull the blade to sharpen it, the screws seem to be too long to get the blade out without removing something, perhaps the chute?
#12 tmacklen OFFLINE
tmacklen
  • 5 Thanks
  • 2 posts
Posted January 24, 2015 - 10:43 AM
here is a manaul I found a while back.  Im having issues with this unit chipping/grinding so will tray to take apart this week to see if I can sharpen the blades.  Many say you can just reverse them.
  • Alc and lyall have said thanks
#13 tmacklen OFFLINE
tmacklen
  • 5 Thanks
  • 2 posts
Posted January 27, 2015 - 01:04 PM
After I dug in to the grinder, I found my grinder blades were different than the manual.  Mine were square large chunks of metal.  I treid removing the drum blades but could not remove the barring to be able to slide the shaft over the welded nut inside the casing.  So I sharpend them attached.
I was able to remove the blade from the chip wheel and sharpen that by removing two bolts that attached the blade to the wheel.
Pics attachted.  I chipped a 2-3: pine log as a test in the chipper shoot and it came out like large sawdust pellets so think it is working now.  Will know more once I take it back to the farm.
  • Alc, lyall and HDWildBill have said thanks
#14 Alc ONLINE
  • 5,813 Thanks
  • 6,822 posts
Posted January 28, 2015 - 06:26 AM
Those are some grinding teeth !!   I only saw chippers with ones that swiveled like a flail mower , guess that's why it's a  grinder ?
#15 outdoorsadventures OFFLINE
outdoorsadventures
  • 1 posts
Posted October 18, 2015 - 06:40 AM
Posted January 24, 2015 - 12:43 PM
Owners Manual Chipper Model 250.8.pdf
I tried to open up the PDF and it error out. Could you repost or emailed me back to get the owners manual for this unit.
Thanks.
