Lgt 145 Open Side Front Wheel Bearing
7 replies to this topic
#1 milkdud OFFLINE
milkdud
  • 67 Thanks
  • 68 posts
Posted September 12, 2013 - 08:06 PM
Had my front rims sand blasted.  Left bearings in and told guy to tape them off.
Well he did not tape them off.  The bearings are all gritty now.  I have no idea why he would not tape them off.
Where would I start looking for front wheel bearings for this?
Thanks
Conrad
#2 Arti ONLINE
Arti
  • 1,371 Thanks
  • 995 posts
  • Location: South West Wisconsin . Now in North Central Mo.
Posted September 12, 2013 - 08:43 PM
I would soak them in some good cleaner and repack them with grease, I suspect that they haven't been damaged yet.
Good Luck with them.
  • milkdud said thank you
#3 milkdud OFFLINE
milkdud
  • 67 Thanks
  • 68 posts
Posted September 12, 2013 - 10:21 PM
I am soaking them in carb dip overnight .  Hope that will eat the grease out them.  Then I can hopefully shake and air blow most of the sand out.
I guess they are not sealed and are ment to be run with "some" dirt in them.
Conrad
#4 KennyP ONLINE
  • 40,866 Thanks
  • 47,088 posts
Posted September 13, 2013 - 04:53 AM
I'd rinse them out real good after the dip.
#5 milkdud OFFLINE
milkdud
  • 67 Thanks
  • 68 posts
Posted September 13, 2013 - 04:19 PM
They were pretty crunchy after the dip and clean.  I found some at NorthernTool.  Just put new ones in.
Thanks
#6 Guest_gravely-power_*
  • Guests
Posted September 13, 2013 - 05:12 PM
Has anybody heard about the cleaning and repacking of wheel bearings? Wash and clean in parts cleaner/mineral spirits/paint thinner, all the same stuff. Blow out with air, DO NOT SPIN!!!! Wash again, dry again and repack. Whats the mystery?
#7 milkdud OFFLINE
milkdud
  • 67 Thanks
  • 68 posts
Posted September 13, 2013 - 05:52 PM
For 5 bucks a piece I put new ones in.   Online you can get them for 2.50 a piece but I was impatient.
Here are the new tires/painted rims.   I put 8.50 tires on instead of 6.50.    It raised the nose up a bit and I plan on mounting 25 or 26's on the back next year.
Conrad
  • KennyP, tinbender7, Russ and 1 other said thanks
#8 KennyP OFFLINE
  • 40,866 Thanks
  • 47,088 posts
Posted September 13, 2013 - 06:32 PM
Glad you got things going again!
