Any Machinists Out There?
16 replies to this topic
#1 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted September 12, 2013 - 01:40 PM
I'm looking for someone who might want to do a little side job.  I would pay or course.  What I am looking at is a design for a category 1/0 pin.  Cat. 1 on one side and cat. 0 on the other.  I have a rough sketch done and can do the finished drawing for you to go by.  I'm doing this because the tractor I just bought has a cat. 1 hitch and the other one that I plan to keep has cat. 0.  I have a rear blade that I would like to be able to put on both of them.  I could use bushings but I think this would be a better overall solution.  I've seen these pins at TSC that take you from cat. 3/2 and cat. 2/1 but the cat. 0 seems to get no love.  If anyone has the talent and machines to do this, contact me and we'll take it from there.  Thanks.
  • boyscout862 and JRJ have said thanks
#2 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted September 12, 2013 - 02:20 PM
check out mcmaster carr they might ave something and btw i think i have seen the cat 1 to 0 pins before somewhere dont know though
#3 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted September 12, 2013 - 02:35 PM
Jeff if this link works, I think this is what you want.
http://www.agrisuppl...campaign=SSIDE/
  • David Brown, boyscout862 and JRJ have said thanks
#4 Grumpy OFFLINE
Grumpy
  • 748 Thanks
  • 624 posts
Posted September 12, 2013 - 03:23 PM
Dave; Where do you live. I'm in southwest Indiana.
Grumpy
#5 MH81 OFFLINE
  • 29,979 Thanks
Posted September 12, 2013 - 06:16 PM
You would almost want a cat 0 with male threaded and a cat 1 with female threads and screw them together. Thru the "ear" mount on the back blade.
  • David Brown said thank you
#6 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted September 12, 2013 - 06:48 PM
No, that's not what I have in mind.  I will post something tomorrow.  The concept drawing is on another computer.  I haven't see anything like what I'm talking about.
#7 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted September 12, 2013 - 06:51 PM
You're on the right track Alan.  This would be all one peice though.  I think it would be stronger that way.  Picture a regular cat. 1 pin installed on a rear blade.  The pin is on the outside, right?  Now when I use the blade on a cat. 0 tractor, the pins have to point in, so the machined cat. 0 pin portion would be on the other end.  The whole thing fastens to the blade as a cat. 1 pin would.
#8 New.Canadian.DB.Owner OFFLINE
  • 2,348 Thanks
  • 1,502 posts
Posted September 12, 2013 - 07:05 PM
Would this work?
http://www.orschelnf.../si6312492/cl1/
#9 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted September 12, 2013 - 08:06 PM
Well that's the bushing and, you're right, I could go that route.  I just wanted to try something a little more solid and not have to worry about bushings.
#10 MH81 OFFLINE
  • 29,979 Thanks
Posted September 12, 2013 - 08:39 PM
What are the diameters of the different sizes?
#11 New.Canadian.DB.Owner OFFLINE
  • 2,348 Thanks
  • 1,502 posts
Posted September 12, 2013 - 09:00 PM
Then how about turning it into a welding project?  Cut a Cat 1 pin and weld it to a Cat 0 pin, or the other way around.
#12 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted September 12, 2013 - 09:04 PM
Cat 1 appears to be 7/8" and cat. 0 is around 5/8".  It is enough to thread the larger dia. and slide the nut over.  Should work out quite well.
#13 nbent ONLINE
nbent
    customizer
  • 679 Thanks
  • 540 posts
Posted September 12, 2013 - 11:32 PM
would you want something like this but in a cat 1 and 0
  • MH81 and David Brown have said thanks
#14 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted September 13, 2013 - 05:48 AM
So here is a rough idea of what I'm trying to accomplish.  I think I have enough general information shown that someone could tell me if they can do this or not.  I think it would work and I know if would suit my situation perfectly.  Who knows, we may even start something here.
#15 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted September 13, 2013 - 05:51 AM
YES!  That's exactly it!  See the post I just put up with my sketch.  Now I know they have larger ones anyway.  Cat. 0 doesn't get a whole lot of respect anymore.  Thanks!  I'll have to search that site and see what I can find.
