Lug Nut Removal Help
27 replies to this topic
#16 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted September 11, 2013 - 07:38 PM
DO NOT USE HEAT!!!!!!!
http://www.youtube.c...h?v=jBUVzgCHHuA
Wow! And I thought a near hernia was painful enough. That not only would have hurt, but I'm pretty sure it would have neutered me as well.
#17 HDWildBill OFFLINE
  • 8,975 Thanks
Posted September 11, 2013 - 08:04 PM
Talk about an eye opener!  Thanks OB.
#18 Canawler OFFLINE
Canawler
  • 1,948 Thanks
  • 1,803 posts
Posted September 11, 2013 - 09:48 PM
....but I'm pretty sure it would have neutered me as well.
Shouldn't be a problem.  You're too old for more kids anyway. :smilewink:
  • MH81 and johndeereelfman have said thanks
#19 OldBuzzard ONLINE
OldBuzzard
  • 7,027 Thanks
  • 4,792 posts
Posted September 12, 2013 - 12:10 AM
You can heat them, just break the bead first. You may think taking the valve core is enough, but it might not be, only so much air can go through it at once.
If you didn't watch that video, I'd suggest that you do.
At 5:50 he talks about one case where the tire was deflated, and the valve stem removed, and then another where the tire DID have the bead broken.
The one with the bead broken actually reseated itself.
Three rules about using heat on a wheel/tire:
1. Don't use it.
2. Don't ever us it.
3. Don't never ever use it.
Edited by OldBuzzard, September 12, 2013 - 12:12 AM.
  • IamSherwood, johndeereelfman, HDWildBill and 1 other said thanks
#20 Alc ONLINE
  • 6,912 Thanks
  • 7,472 posts
Posted September 12, 2013 - 07:38 AM
I just sent my boos this thread to have him show that video at safety meeting because I know I've used a torch to heat rusted lug nuts . and I'm sure others I work with did too , thanks OB
#21 AVB OFFLINE
AVB
  • 138 Thanks
  • 135 posts
Posted September 12, 2013 - 08:03 AM
I used to have to cut the nuts off after our tire man got a hold of them. I couldn't do a brake job on a MP car without replacing a few studs.
That video was an eye opener.
  • Alc and johndeereelfman have said thanks
#22 olcowhand ONLINE
  • 41,274 Thanks
  • 31,449 posts
Posted September 12, 2013 - 08:52 AM
That's why I said trailer it to a tire guy.  They have guns to overly tighten, as well as remove them.
#23 lyall ONLINE
lyall
  • 2,072 Thanks
  • 1,545 posts
Posted September 12, 2013 - 02:57 PM
some times if you try tighting a nut a litttle and try removing the nut some times it comes off
  • olcowhand, johndeereelfman and HDWildBill have said thanks
#24 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted September 18, 2013 - 08:38 PM
Just an update. I went out tonight to give each of the lug nuts another tap, and another dose of penetrating oil. Figured I might as well try them again to see if there were any changes, and sure enough, they all finally broke loose. And no damage to the 1/2" breaker bar, 11/16" socket, or to the studs. So now with the wheels removed from the hubs, I can finally order new brake shoes, and get the transmission transferred from this H1 over to the H3.
Thanks for all of the help guys, I appreciate the advice!  :thumbs:
  • olcowhand, MH81, Alc and 2 others have said thanks
#25 MH81 OFFLINE
Posted September 18, 2013 - 08:41 PM
Glad you didn't break your nuts ... Um, er...
Well, glad you got the wheels off.
Thanks for the update.
Good luck with the brakes.
  • johndeereelfman and boyscout862 have said thanks
#26 lyall ONLINE
lyall
  • 2,072 Thanks
  • 1,545 posts
Posted September 18, 2013 - 09:47 PM
sure glad you got the wheels off with out breaking anything
now the fun begins
#27 HDWildBill OFFLINE
  • 8,975 Thanks
Posted September 19, 2013 - 09:34 AM
What penetrating oil did you end up using?  Glad you got the wheels off with no damage.  :thumbs:
#28 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted September 20, 2013 - 08:05 PM
I'll have to check Bill, but I think the can is marked 77. I think the can has a red paper label with blue lettering. We use the stuff at work when we are servicing coiling roll up doors, and the stuff usually works pretty fast. I'll check it out tomorrow and let you know the name of it.
  • HDWildBill said thank you
