Lug Nut Removal Help
27 replies to this topic
#1 johndeereelfman OFFLINE
johndeereelfman
  • 5,709 Thanks
  • 2,597 posts
Posted September 10, 2013 - 08:57 PM
Ok guys. I was given a 1974 140 parts tractor to complete my 1972 140, and I have the motor removed. As for the transmission, I'm having issues with removing the lug nuts. On the later 140's, you screw on a nut to hold the wheels to the brake hub studs. Anyhow, on the left rear, there are three nuts that are rusted fast to the lugs, and I've been soaking them with penetrating oil for the past week and a half, tapping the nuts with a hammer and screw driver each day. I tried again tonight to try and get the nuts off, and just about gave myself a hernia. These suckers are on there tight. So far, I've tried a 1/2" impact gun, heat, and a 1/2" socket wrench with the big breaker bar, and they aren't even trying to budge. Any recommendations out there that I might try and use to get these things off? I don't want to ruin the studs, but I guess if that is the only thing left to do, then so be it.
The tires on this tractor are in need of tubes, but I'm not looking forward to installing tubes while the wheel is still mounted to the tractor. I also need to replace the brake on this same rear, but I can't do that until I can get the lugs and wheel off. The sooner I get this tractor disassembled, and the 72 140 completed, the sooner I can roto-till the garden before fall sets in.
#2 DH1 ONLINE
DH1
    Electric Tractors
  • 5,012 Thanks
  • 5,462 posts
Posted September 10, 2013 - 09:14 PM
Breaker bar and slide a
6' pipe over it.
PULL
  • johndeereelfman and dropped82 have said thanks
#3 MH81 ONLINE
  • 29,936 Thanks
  • 29,753 posts
Posted September 10, 2013 - 09:27 PM
Acetone and ATF?
Cherry red just the nut and then candle or bees wax? (There WILL be a flame here BTW)
#4 Ryan313 OFFLINE
  • 3,242 Thanks
  • 5,159 posts
Posted September 10, 2013 - 09:34 PM
How big is your breaker bar? The other day I was trying to remove the wheels on my log splitter and was having trouble with a 3/4" breaker bar, so I put a big pipe on it and was lifting the splitter! Although, once I swung i around so it was down pressure it came right off.
#5 AVB OFFLINE
AVB
  • 138 Thanks
  • 135 posts
It will probably just be easier to break the studs.
#6 NUTNDUN OFFLINE
  • 10,299 Thanks
Posted September 11, 2013 - 04:41 AM
I vote for the breaker bar with pipe slid over. I would think with a long enough pipe it is either going to break loose or break the stud, just watch your knuckles :D
#7 IamSherwood OFFLINE
  • 8,385 Thanks
Posted September 11, 2013 - 06:41 AM
Troy, is it possible that someone put left hand thread studs in there. I'm not familiar with
the JDs, so IDK if that even makes any sense.
Other than that, I'd say get it RED hot, 6 point 1/2" socket, breaker bar and 4ft pipe.
It's gotta move or break.
  • johndeereelfman and oldedeeres have said thanks
#8 JDBrian OFFLINE
  • 9,596 Thanks
Posted September 11, 2013 - 06:58 AM
Those studs are hard but eventually with enough force you will break them. With enough heat they should come loose. It sometimes seems like things like that are welded together.
  • johndeereelfman and boyscout862 have said thanks
#9 boyscout862 ONLINE
  • 11,459 Thanks
  • 8,478 posts
Posted September 11, 2013 - 07:41 AM
Patience. I've soaked wheel cylinder bleeding nipples for 6 months with PB Blaster and then they came off easy. I couldn't get the hydraulic lines on my backhoe to come loose so I've been soaking them for 2 months and trying each week. I'll try again this afternoon. If I damaged the steel lines it would be difficult and expensive. Its better to be patient.
 The homemade penetrating oil that the site has instructions on seems to work well for others. If you have the time, give it a try for a couple of weeks. Then, heat them and turn them off. Good Luck, Rick
#10 olcowhand ONLINE
  • 38,062 Thanks
  • 30,461 posts
Posted September 11, 2013 - 08:25 AM
Sounds like you need a stronger impact gun.  BIG difference between cheaper & high end.  Maybe you can borrow a high end one from a shop, or even trailer the tractor to a tire shop & just have them pop them off..
#11 HDWildBill OFFLINE
  • 8,971 Thanks
Posted September 11, 2013 - 09:17 AM
Acetone and ATF?
I was thinking Acetone and ATF as well.  Soak them really well then heat them up and use the breaker bar and a pipe on the end of it.  I have a  5' pipe in the shop just for these type situations.  :D
#12 OldBuzzard OFFLINE
OldBuzzard
  • 6,837 Thanks
  • 4,737 posts
Posted September 11, 2013 - 12:36 PM
DO NOT USE HEAT!!!!!!!
http://www.youtube.c...h?v=jBUVzgCHHuA
Edited by OldBuzzard, September 11, 2013 - 12:37 PM.
  • MH81, Alc, IamSherwood and 5 others have said thanks
#13 Ryan313 OFFLINE
  • 3,242 Thanks
  • 5,159 posts
Posted September 11, 2013 - 04:13 PM
You can heat them, just break the bead first. You may think taking the valve core is enough, but it might not be, only so much air can go through it at once.
#14 boyscout862 ONLINE
  • 11,459 Thanks
  • 8,478 posts
Wow, that is scary. Thanks, rick
  • HANKG said thank you
#15 johndeereelfman OFFLINE
johndeereelfman
  • 5,709 Thanks
  • 2,597 posts
Posted September 11, 2013 - 07:36 PM
Will, they are the original studs with right hand threads. I'll keep soaking them with penetrating oil for another week, and if they still don't budge, I'll try the other suggestions that you guys gave.
