My Welder Arrived!
14 replies to this topic
#1 Ryan313 OFFLINE
  • 3,369 Thanks
  • 5,231 posts
Posted September 10, 2013 - 05:54 PM
Some may have seen my other thread (HERE) where I was asking for reviews of a welder I wanted to buy. Originally I was going to get a Miller Thunderbolt, but then I found I could get a Hobart Stickmate online for $140 cheaper, and it is the same welder on the inside! So, I ordered myself one; it arrived today!
They even built a little pallet for it! Here it is after I removed the plastic wrap.
CB1F372F-CC8C-4F3E-BDFF-583D55BBD442-269
Before it arrived, I went online and found the dimensions of it so I could build a cart and have it ready when it arrived. I made sure to go to more then one site to get dimensions, and since they where all the same I figured that they must have been right... nope! My cart is not the right size! However, it is the correct width, so it will work for now.
62E22374-9F95-4CA0-9D30-3D32F68F0957-269
I can tell that the MIG and plasma cutter are happy to have some more company.
F2F25563-D015-4BDC-9176-4230F4A6B9E5-269
I would love to be able to tell you guys that it works great... but I can't! The outlet is the wrong style! I need the one with the three flat prongs, not two flat and a round. I will go get another outlet in a few minutes.
8374FB7F-2F02-4519-A5B2-86C25AA3D76B-269
At first appearance, the only thing I don't like is the work clamp; it is very cheap. It does not look like a bad clamp, but it is all steel and has steel teeth. I am going to replace it with a clamp that has nice copper pads on the ends. I don't like the steel because it will not get the conductivity of copper, and I am sure that the small amount of contact provided with the original clamp will cause quite a bit of resistance.
  • olcowhand, powerking56, Gtractor and 8 others have said thanks
#2 IamSherwood OFFLINE
  • 8,391 Thanks
Posted September 10, 2013 - 06:01 PM
Nice.
It's starting to look like a HF store under that bench.
Oh, what's with the extra clean bench. That doesn't seem right.. :D
  • Ryan313 said thank you
#3 TomLGT195 OFFLINE
TomLGT195
  • 3,833 Thanks
  • 2,816 posts
Posted September 10, 2013 - 06:07 PM
nice score, looks like you'll be the go to guy in your area for metal fab work  :smilewink:
good luck
#4 Ryan313 OFFLINE
  • 3,369 Thanks
  • 5,231 posts
Posted September 10, 2013 - 06:13 PM
good luck
I am hoping so! I already have people wanting stuff made! Right now I have a plow mounting bracket for a Dodge 1500 that the guy hit a speedbump with and bent up, he was going 55 mph... The bump was just put in and not painted yet so he didn't see it. This weekend I am going to do some repairs on a skid steer, and I have another guy who wants me to build him a flatbed for a Chevy 3500 he just bought!
  • TomLGT195 said thank you
#5 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted September 10, 2013 - 06:33 PM
Starting to look like the shop of a pro welder, Isn't it nice to have the right tool to do the job like you want to,
Dick
#6 powerking56 OFFLINE
powerking56
    Collector of stuff
  • 909 Thanks
  • 1,805 posts
Posted September 10, 2013 - 07:17 PM
looks good, nice to have some good tools to get the job done right and sounds like the word is out that you can fix/fab things for folks!!
#7 gopher OFFLINE
gopher
  • 764 Thanks
  • 758 posts
Posted September 10, 2013 - 07:29 PM
Nice looking welder. I'm sure that when they give overall dim they go from out most  that would be your adjustment crank and nice arc in power cord so not kinked . You could drill couple holes in frame and put couple of angle brackets like they use to hold stoves from tipping.
#8 Cvans ONLINE
  • 6,668 Thanks
  • 6,134 posts
Posted September 10, 2013 - 08:07 PM
Looks good!  :thumbs:
Does this welder have thermal protection? If your like me and most other people the duty cycle on these welders tends to  be ignored. Keep an eye on it during hot weather and you should be fine.
Enjoy your new welder.
#9 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted September 10, 2013 - 08:19 PM
Nice looking machine Ryan. I got a used stick machine last year, bought the outlet but haven't gotten around to installing it yet.  It sounds like you have a nice little fabrication business on the go!
#10 Cat385B ONLINE
    HAZMAT CAT
  • 13,989 Thanks
  • 10,009 posts
Posted September 10, 2013 - 08:29 PM
Ooh, post pics of the flatbed build if you do that. I love a good flatbed!
#11 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted September 10, 2013 - 09:07 PM
ME TOO!!
#12 Ryan313 OFFLINE
  • 3,369 Thanks
  • 5,231 posts
Posted September 10, 2013 - 09:23 PM
I went to Home Depot to get a new plug, and after what I thought was a very expensive plug at $16, I was on my way home to put it on. I got it on and tested it out! The first thing I noticed was how smooth the arc was! It was amazing! Not only was it better then the Lincoln Idealarc 250 machines we have in welding class, but it was better then a Miller Trailblazer!
Here are the welds I made with it, they where all in the flat position; I did not have time to mess around with vertical or overhead. Some are decent, and some are horrific, none of them I was 100% happy with.
38B77D26-F7B4-48DB-8B50-E77EB69848DE-274
While I was using it, I was so excited about how smooth the arc was, I forgot to try the other polarities, I will try them tomorrow. :D
The only thing I did not really like was the stinger; the grooves that hold the rod are not very deep, and it is hard to get the rod into them perfectly. I have another stinger that is almost brand new, and it is much better, I will put that one on tomorrow.
So far, everything seems to what I expected and more!
#13 Ryan313 OFFLINE
  • 3,369 Thanks
  • 5,231 posts
Posted September 10, 2013 - 09:29 PM
That is exactly what it is! I noticed that earlier when I was changing the plug.
Unfortunately, it does not have thermal protection, and that is something that I was worried about. I know that I go past the duty cycle on my MIG quite a bit, and sometimes I run it at 2 or 3 times the duty cycle without noticing until I am done with what I was doing. Although I am going to try not to do it with this one, I don't think it will do it intentionally. Have you ever seen ChuckE2009 on youtube? He has the same welder and claims to have used it at twice the duty cycle for 5 hours (if I remember correctly) while repairing a forklift.
  • Cvans said thank you
#14 Cvans ONLINE
  • 6,668 Thanks
  • 6,134 posts
Posted September 10, 2013 - 09:37 PM
Haven't seen any of Chuck's videos but I'd be willing to bet that they figure in a good safety margin on the duty cycle. Something I should check on the Thunder Bolt is to see if it has thermal protection.
#15 Ryan313 OFFLINE
  • 3,369 Thanks
  • 5,231 posts
Posted September 10, 2013 - 09:43 PM
He makes some very good videos! I would say he is up there with Jody on the welding videos.
The thunderbolt will not have it either, it is EXACTLY the same, other then the pretty blue cover.
