Hyd. Pump?
7 replies to this topic
#1 KennyP ONLINE
  • 38,414 Thanks
  • 45,945 posts
Posted September 09, 2013 - 07:38 PM
Anybody have a clue of the brand name for this pump?
It has a 7/8" shaft with 1/4" keyway. Cast #'s are 31665-1. There are some numbers stamped into the rear, but the first two are all I can make out. They are 71???????. Now even sure how many #'s are there.
I got this with the 2 Char-Lynn motors this weekend.
  • Dieselcubmike said thank you
#2 olcowhand ONLINE
  • 41,205 Thanks
  • 31,433 posts
Posted September 09, 2013 - 07:43 PM
Kenny, i just posted about this pump in your "haul" thread.  Looks to be a roller pump for low pressure water use.  Definitely not hydraulic.
#3 KennyP ONLINE
  • 38,414 Thanks
  • 45,945 posts
Posted September 09, 2013 - 07:59 PM
Just read that! Thanks! Oh well, it was cheap!
#4 Arti OFFLINE
Arti
  • 1,363 Thanks
  • 989 posts
I would guess Delavan or Danfoss. We used them when I was a kid. If Memory is correct they would produce around 50 psi on a 540 pto tractor.
#5 IamSherwood OFFLINE
  • 8,391 Thanks
Posted September 09, 2013 - 08:01 PM
I've seen that "D" in second picture before.
Denison rings a bell.....Maybe, or maybe just a buzzer.
"flush with oil....."
As dan said, either a water pump, or ....?
#6 chris m OFFLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted September 09, 2013 - 08:21 PM
Daniel and Arti nailed this one for you Kenny. It is an old Delavan 4 roller pump, mostly used for sprayers. But it could be used for other things also. they where usually rated around 150 psi @ close to 10 Gpm. They still make them today even.
#7 KennyP ONLINE
  • 38,414 Thanks
  • 45,945 posts
Posted September 10, 2013 - 05:01 AM
Glad to get that figured out now. Those 3/4" inlet & outlet had me wondering. Thanks everyone.
#8 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted September 10, 2013 - 10:14 AM
Still a good find!! Just what you need if your building a Sprayer
