Testing J D 332 Diesel Alternator..
20 replies to this topic
#16 olcowhand ONLINE
  • 43,184 Thanks
  • 32,014 posts
Posted October 10, 2013 - 11:00 AM
ALC, it's simply a belt driven stator, wired as a loop circuit, just Like the Kohler K series stators.  Seems like all the belt driven stator system on Deere's all get the wires hot at the regulator ends.  The Kubotas, as with the G4200 I had also use a stator like these, yet I've not seen them get their wires hot like this.  May be an issue with the type regulator John Deere uses, so maybe using one off a G4200 might work better????
  • Alc and Texas Deere and Horse have said thanks
#17 Alc ONLINE
  • 7,362 Thanks
  • 7,641 posts
Posted October 10, 2013 - 03:40 PM
Thanks for the explainion . Now I'm going to have to see how hot the connections are on the 318 that uses something close to that setup and the battery is now on its wayout so it should be trying hard to get the voltage up after starting . Pretty sure the regulator has a built in heat sink .
#18 1971Deere OFFLINE
1971Deere
  • 48 Thanks
  • 66 posts
Posted October 10, 2013 - 05:05 PM
There is a Service bullitin on this problem, I have attached some jpgs of it. Hopefully you can read it ok.
The forum resizes them, I can send you the original pics if needed.
Edited by 1971Deere, October 10, 2013 - 05:07 PM.
#19 Texas Deere and Horse OFFLINE
  • 14,901 Thanks
  • 15,518 posts
Posted October 10, 2013 - 09:56 PM
Al, Here is a couple photos of the Alternator that is used on 330, 332 and 322 Yammar powered John Deeres and the burnt wires.
#20 Alc ONLINE
  • 7,362 Thanks
  • 7,641 posts
Posted October 11, 2013 - 05:44 AM
Jeff that service bullitn will come in handy some day for sure , I saved it because I know I won't remember when the time comes all the things to check lol
  • Trav1s and twostep have said thanks
#21 Trav1s ONLINE
Trav1s
  • 3,655 Thanks
  • 4,606 posts
Posted October 11, 2013 - 09:02 AM
Ditto!
  • awickerham said thank you
