Simplicity Walk Behind
simplicity two wheel
19 replies to this topic
#16 DougT OFFLINE
DougT
    Dog Approved
  • 7,071 Thanks
  • 5,057 posts
Posted September 14, 2013 - 10:44 PM
Update!
I pulled the starter cover off. And, the coil has melted! Looks like I'm in the market for a new coil!
Is it a 2 legged coil or a 3 leg? If its 2 legged, you can use the modern electronic ignition on it and eliminate the points under the flywheel.
  • Rock farmer said thank you
#17 simplemanbrat OFFLINE
simplemanbrat
  • 12 Thanks
  • 14 posts
Posted September 15, 2013 - 01:41 AM
Could be ether 6B or 8B. The only way I see to tell the difference is 6B has 2.00" bore and 8B has 2.25" bore. Both have 2.00" stroke. When I review the parts list, they share many parts.
#18 achomesteader OFFLINE
achomesteader
    GT Fanatic
  • 867 Thanks
  • 2,231 posts
Posted September 15, 2013 - 07:41 AM
Your tractor appears to be a Simplicity Model B with a replacement engine.
You can download the owner's manual and parts list here:
http://gardentractor...r-parts-manual/
#19 Rock farmer ONLINE
Rock farmer
  • 1,221 Thanks
  • 1,245 posts
Posted September 15, 2013 - 10:08 AM
It's a three leg coil. I saw somewhere that I could replace the flywheel with a modern one and use a new coil? Would most any verticle shaft flywheel do?
Thanks!
Joe
#20 VSTROM803 OFFLINE
VSTROM803
  • 373 Thanks
  • 338 posts
Posted September 17, 2013 - 04:28 AM
If you want to replace that coil, try these folks.
http://www.ebay.com/...item35ca1c8e0a
I bought one for a Briggs 143402.
  • Alc and Rock farmer have said thanks
