Magneto For Grandpa 610748 Is Part Number
12 replies to this topic
#1 Ksmith203 OFFLINE
Ksmith203
  • 5 posts
Posted September 08, 2013 - 06:59 PM
I am looking for a magneto for my grandpa. He is over 80 so he is not much for computers. He has a sears lawn tractor but the magneto has become grounded out. Again the part number is 610748. I have been searching but unable to find one for him so I came here to the experts.
#2 KennyP ONLINE
  • 37,377 Thanks
  • 45,442 posts
Posted September 08, 2013 - 07:07 PM
Welcome to the forum!
What tractor & engine is this for?
#3 Ksmith203 OFFLINE
Ksmith203
  • 5 posts
Posted September 08, 2013 - 07:14 PM
Sears lawn tractor
10 hp
Serial number 1229
Model no 91725720
#4 Ksmith203 OFFLINE
Ksmith203
  • 5 posts
Posted September 08, 2013 - 07:18 PM
Tecumseh engine
#5 Guest_gravely-power_*
  • Guests
Posted September 08, 2013 - 07:21 PM
This is the first I found. Yeah it's an HH100
http://www.ebay.com/...=item4ac8ff3f3a
#6 Ksmith203 OFFLINE
Ksmith203
  • 5 posts
Posted September 08, 2013 - 07:26 PM
I just found the same one but grandpa wants to spend less than 100.00 or sell the tractor. I will post pics tomorrow after work.
#7 Guest_gravely-power_*
  • Guests
Posted September 08, 2013 - 07:36 PM
Tecumseh stuff is running out and getting pricy.
#8 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted September 08, 2013 - 08:23 PM
610748 is a solid state ignition unit.  I don't mean to burst the bubble, but I sell them fast at $175 when I find them.  That's about where you will need to be to get it replaced.
Are you sure yours is toast?  Did you disconnect the ground wire completely and see if you get a spark then?  Do you have a good spark plug?  I've been known to replace the boots/connectors and sometimes that fixes the problem.
Ben W.
  • sacsr and boyscout862 have said thanks
#9 DougT OFFLINE
DougT
    Dog Approved
  • 6,846 Thanks
  • 4,948 posts
Posted September 08, 2013 - 08:38 PM
You can find a cheaper solution to the Tec ignition here:  www.enginesandmagnets.com
#10 boyscout862 OFFLINE
  • 12,517 Thanks
  • 9,027 posts
Posted September 09, 2013 - 05:20 AM
Welcome to GTT. Take your time and fix the tractor. Hang on to it. Check out the manuals section. Good Luck, Rick
#11 crittersf1 ONLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted September 09, 2013 - 07:33 AM
:welcometogttalk: :wewantpics:
#12 TAHOE OFFLINE
TAHOE
  • 7,808 Thanks
  • 5,610 posts
Posted September 09, 2013 - 09:14 AM
There are other more modern upgrades to the old SSI module ( not a magneto)  igntion for much cheaper, but your grandpa is still looking at $100-150 for new parts.
The cheapest upgrade is Ed stoller's system on the engines and magnets website  posted above. You can pickup his homemade trigger for about $35-40 shipped, then grab as Chrysler control module , and coil at local auto store for about $25 each. Follow Ed's directions and you can have it running. This does convert it to a battery-coil igntion so tractor really needs a good charging system.
Ed's buddy Mike on his website also sells a complete kit for about $139 shipped or around that.
You can also check out Dale Colvert at  http://overnight-solutions.com/ for a drop in, modern upgraded replacement. it runs around $150 I think.
I also have converted one using a different type of pickup and magnets in flywheel, bat that will run you close to $150 also.
I personally would stay away for the used Ebay used modules, I wouldn't spend $200 plus on a 40 yr old electronic part that may go out tormorrow when it can be upgraded to modern day parts.
I've done a conversion already on a 16Hp, will need one for my other 16 and probably my 12. Let me know if ya need some help, I can talk ya through it. Only one I'm not really familiar with is the overnight solutions, but another guy I know did it and it's pretty much a plug and play system.
I've been working on building my own trigger too using he old module with Ed's help.
#13 Ksmith203 OFFLINE
Ksmith203
  • 5 posts
Posted September 12, 2013 - 11:34 AM
Wow you are a great group. I work lots of hours so this is the first I could get back on. I will check into eds and go that route. Thanks for the help!
