Plough or Plow Guide
plow identification
52 replies to this topic
#46 bread320i OFFLINE
bread320i
  • 613 Thanks
  • 1,225 posts
Posted April 09, 2016 - 07:26 AM
Had someone I didn't even know call last nite and then deliver me this plow. Looks to be one for a 1920-30's Red-E tractor. I used to have a 28 model, wished I would have kept it now.
Whats your plan with the plow?
  • Lauber1 said thank you
#47 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted April 09, 2016 - 09:12 AM
haven't really had the time to make any plan for it. been pretty deep into building PJ attachments and never went any further than figuring out what it was off of. Do you have a plan for it? might trade it for a Pj cultivator.
#48 FixItCharlie ONLINE
FixItCharlie
  • 518 Thanks
  • 336 posts
Posted April 17, 2016 - 12:26 PM
I finally got around to mounting the plow on the tractor.
One thing that I found that does not seem right is when the plow is raised the coulter will swing to where it hits the sleeve hitch. The coulter needs to swing some when the offset is adjusted. My question should I drill & tap this for a set screw to lock it in placed. Looking at pictures of other plows the coulter it looks that the coulter has no side to side movement.
Charlie
  • Lauber1 and Bolens800uk have said thanks
#49 KennyP ONLINE
  • 37,496 Thanks
  • 45,506 posts
Posted April 17, 2016 - 02:28 PM
Charlie
There should be a roll pin that restricts the movement.
#50 FixItCharlie ONLINE
FixItCharlie
  • 518 Thanks
  • 336 posts
Posted April 17, 2016 - 08:21 PM
With the way the mounting for this coulter I think a set screw mi9ght be better.
Charlie
#51 MH81 OFFLINE
Posted April 20, 2016 - 11:51 AM
I would allow for some movement, but restrict it.
Making the mount solid can have bad circumstances if you hit something. I know I had hit some rocks hard with the Sears coulter and am waiting for it to bend. The big ones all have some limited movement. So do most of the GT sized ones.
  • FixItCharlie said thank you
#52 Mike Unwin OFFLINE
Mike Unwin
  • 403 Thanks
  • 303 posts
Posted March 12, 2017 - 02:45 PM
And another plow mystery solved by ...glgrumpy
This would be a Speedex plow
  • DH1 said thank you
#53 jimmy G ONLINE
jimmy G
  • 1,178 Thanks
  • 762 posts
Posted March 24, 2017 - 02:26 AM
This is the smaller Simplicity 6 1 / 2 and 8 inch plow, maybe some one has a real picture to add.  This was Brinly plow Thanksattachicon.gifSimplicity Plow 6 and 8 Inch.jpg
I believe this is the smaller one,MH81 posted one on the bottom of the first page which looks a little bigger,the green paint on mine is not rattle can or brushed,rebadged?
Also tagged with one or more of these keywords: plow, identification
