Plough or Plow Guide
plow identification
52 replies to this topic
#1 Mike Unwin OFFLINE
Mike Unwin
  • 403 Thanks
  • 303 posts
Posted September 06, 2013 - 07:05 PM
I was wondering if maybe we all could contribute to a Plow Guide,because over the years implements and tractors get separated . If you are sure of your plow attach a name and little info to your picture.Maybe could be a "pinned " topic .Some equipment would be regional I think, I have a Waterloo and a Empire plow probably local to Canada . Any takers ? Cheers Mike
  • NUTNDUN, Texas Deere and Horse, Lauber1 and 4 others have said thanks
#2 Bob IN OFFLINE
Bob IN
  • 1,477 Thanks
  • 676 posts
Posted September 06, 2013 - 08:00 PM
Ill help with that. Here's one to the list. (Try and get some other pictures taken tomorrow. This is my standard walsh and standard walsh plow.
  • earthgrinder and Mike Unwin have said thanks
#3 Mike Unwin OFFLINE
Mike Unwin
  • 403 Thanks
  • 303 posts
Posted September 09, 2013 - 10:57 AM
This is a Planet Jr. plow with Model NPR6 Briggs engine,smaller type courtesy Jim. H.Planet Jr 2 small.jpg Planet Jr. small.jpg Planet Jr 3 small.jpg
#4 Mike Unwin OFFLINE
Mike Unwin
  • 403 Thanks
  • 303 posts
Posted September 09, 2013 - 10:59 AM
This is a David Bradely Plow Model 917 57552 with Sears Tag.David Bradely small.jpg David Bradely 2 small.jpg David Bradely 3 small.jpg
Courtesy Jim H.
Edited by Mike Unwin, September 09, 2013 - 11:00 AM.
#5 Mike Unwin OFFLINE
Mike Unwin
  • 403 Thanks
  • 303 posts
Posted September 09, 2013 - 11:08 AM
This is a Empire Model X plow,or what is left of it.Empire Model X small.jpg Empire Model X 2 small.jpg Empire Model X 3 small.jpg
#6 Mike Unwin OFFLINE
Mike Unwin
  • 403 Thanks
  • 303 posts
Posted September 09, 2013 - 01:45 PM
This is the smaller Simplicity 6 1 / 2 and 8 inch plow, maybe some one has a real picture to add.  This was Brinly plow ThanksSimplicity Plow 6  and 8 Inch.jpg
#7 Mike Unwin OFFLINE
Mike Unwin
  • 403 Thanks
  • 303 posts
Posted September 09, 2013 - 01:46 PM
This is the larger Simplicity 10 inch plow also Brinly made .Simplicity Plow 10 Inch.jpg
#8 bignick1 OFFLINE
bignick1
  • 11 Thanks
  • 5 posts
Posted September 24, 2013 - 11:01 AM
the plow is a brinly but made for cub cadet
  • Mike Unwin said thank you
#9 OldBuzzard ONLINE
OldBuzzard
  • 6,984 Thanks
  • 4,783 posts
Posted September 24, 2013 - 01:59 PM
Here are pics of an Ohio Steel 10" sleeve hitch plow and a Brinly 12" 3-pt plow.
The Ohio Steel plow uses a piece of all thread and four nuts to adjust the digging angle. That's how to distinguish it from the Brinly sleeve hitch plow which usually has the crank for adjusting.
#10 Mike Unwin OFFLINE
Mike Unwin
  • 403 Thanks
  • 303 posts
Posted September 24, 2013 - 04:51 PM
Interesting the use of a depth wheel, my Empire used a wheel and support borrowed from the cultivator to do that course when you take a wheel off something it is easy to get lost like mine.
#11 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted November 14, 2013 - 09:45 PM
my plow got it working good
  • MH81, Alc and Mike Unwin have said thanks
#12 Mike Unwin OFFLINE
Mike Unwin
  • 403 Thanks
  • 303 posts
Posted November 21, 2013 - 08:53 AM
Thanks HomkoBot, this is a Bolens Gardener Plow .another day another plow !
#13 Talntedmrgreen OFFLINE
  • 3,230 Thanks
  • 2,300 posts
Posted November 24, 2013 - 08:49 AM
This is the smaller Simplicity 6 1 / 2 and 8 inch plow, maybe some one has a real picture to add. This was Brinly plow Thanksattachicon.gifSimplicity Plow 6 and 8 Inch.jpg
Brinly did not offer a plow through Simplicity until the mid '70's. Prior to that, Simplicity Manufacturing produced Simplicty and Allis plows. These pictured are Simplicity built, not Brinly.
Simplicity built most of their own attachments, with the exception of those listed as 'Allied' attachments, and units like the loaders (Henry), Groundsaw (Hawk) and Post Hole Digger (Danuser).
This is an Allis mfg #2029904
It's twin, is the Simplicity mfg #990204 & 990464
The Simplicity # fo rhte 10" Brinly is 1690098
This is the same 3pt 12" Brinly shown above, but available for Simplicity PowerMax tractors and equivilents under Simplicity #1600200
#14 Mike Unwin OFFLINE
Mike Unwin
  • 403 Thanks
  • 303 posts
Posted December 07, 2013 - 02:55 PM
Here is a plow off a 3 point hitch Sears ST -12 tractor 1976 vintage while the plow is the same colour the cross bar was added later ,sorry for the confusion,Thanks MH81. So the plow itself is unknown to me,can anyone help ?
Edited by Mike Unwin, December 08, 2013 - 01:47 PM.
#15 MH81 OFFLINE
Posted December 07, 2013 - 04:21 PM
Here is a Sears ST -12 plow circa 1976 ,this tractor had the Sears 3 Point hitch .
Actually, I think that's a plow from a simplicity (or wards) walk behind unit.
Looks like someone added the cross bar for a sears.
Here is a walk behind plow from that era. the hitch is different, but look at the pivot and adjustment (aiming back so you can adjust as you walk behind).
Here is the plow commonly used by Simplicity Riders
The plow above may not actually be simplicity, but it sure is similar is several ways.
Also tagged with one or more of these keywords: plow, identification
