New To Me 646
646 diesel repower
18 replies to this topic
#16 Case-Closed OFFLINE
Case-Closed
  • 309 Thanks
  • 155 posts
Posted September 25, 2013 - 04:48 PM
I am going to definately run into space problems, I will need to cut the engine drive shaft off a bit in order to make things fit better. Does anyone out there have a source  for  the adaptor I will need to go from the engine to the pump. I have the lovejoy for this but not the adaptor.
#17 Boss 448 OFFLINE
Boss 448
  • 48 Thanks
  • 248 posts
Posted September 27, 2013 - 11:39 AM
There are usually a selection of hydraulic pump mounts available on E-Bay, but the selection is limited and it can be hard to determine all of the dimensions. Some of the E-Bay selections may be a good value, but some of them are not much cheaper than going direct to companies that sell them. The Northern Tool website lists some on their website also. Here is a link to a manufacturer of engine to pump mounts - I think you can download their catalog - http://www.vescor.com/GasAdapters.htm. Hope this helps.
JN
#18 Utah Smitty OFFLINE
Utah Smitty
  • 1,705 Thanks
  • 1,789 posts
Posted November 13, 2013 - 06:07 AM
Herb--
I have an adapter for a 446 Case with the Onan, even have 1=side of the Lovejoy--not sure which--may have an adapter for the Kohler. it'll take me a couple days to check...
Smitty
#19 Utah Smitty OFFLINE
Utah Smitty
  • 1,705 Thanks
  • 1,789 posts
Posted November 13, 2013 - 06:10 AM
New Kohler is in the house and the fitting has begun, fotos will soon follow.
So, is your Kohler gas or diesel?
Smitty
Also tagged with one or more of these keywords: 646, diesel, repower
