New Mf12G Owner
203 replies to this topic
#166 MH81 OFFLINE
  • 30052 Thanks
  • 29761 posts
Posted February 19, 2014 - 08:46 PM
Oh, it isn't the alternator, it's the regulator. Now I understand.
I've seen a few different regulators rewired into these and they seem to work ok with some rewiring.
Other than the splicing, what is wrong with your regulator. Is the unit charging ok?
#167 cheluIS OFFLINE
cheluIS
  • 164 Thanks
  • 100 posts
Posted February 20, 2014 - 01:38 PM
The regulator is charging OK but I want to change it . The way my regulator looks I can expect problems so I want to have a spare.
So if you have any informations , please share.
Thanks.
#168 cheluIS OFFLINE
cheluIS
  • 164 Thanks
  • 100 posts
Posted February 20, 2014 - 03:57 PM
Found this :Regulator Rectifier Tecumseh 610749, AM102596, 610749 (http://www.ebay.com/...480bf4a&vxp=mtr)
Bought it , hope in 10-12 days I'll receive it .
Meanwhile study , study , study for tachometer connection. Had to buy another counter frequency meter . The old one just fell down from the engine while measuring .Dead !!! :wallbanging:
Keep in touch .
#169 MH81 OFFLINE
  • 30052 Thanks
  • 29761 posts
Posted February 20, 2014 - 06:19 PM
Keep in touch .
Aw, that's bad. Sorry to hear you lost your meter.
Good luck on the regulator.
#170 cheluIS OFFLINE
cheluIS
  • 164 Thanks
  • 100 posts
Posted February 21, 2014 - 03:23 PM
Read a lot and done a lot of tests .
From the ignition coil couldn't have a good signal .Found out that the tachometers instaled in trucks and cars take signal from alternator , point "W" .So I took signal from one of AC alternator wire.
The tachometer has a push button for settings that sets from 1.0 to 10.0 in 0.1 steps .Don't ask me what this do .With setting 5.9 it works .I have to take the MF outside to make extensive tests .My wife is not happy with me reving the engine indoors. :cowboy_shooter:
Made the "calibration" with my old laser tachometer .Here is another problem . The gases from exhaust are interfering with the laser beam and give me sometime wrong readings . So again I have to take it outside .
A little test :
The hourmeter is working.
I think I'm on the good way .
One more thing . Call me stupid :hitting_self_roller: but after watching the video with tachometer I had a revelation : the ampermeter shows a number with "-" when it draws current and without "-" when the battery is charging .
I see that at high revs the voltmeter shows 14.5V . Is this normal ?
And I put about 2 litres of gas in the tank and the floater is working too .
Keep in touch .
  • IamSherwood and Gabriel have said thanks
#171 MH81 OFFLINE
  • 30052 Thanks
  • 29761 posts
Posted February 21, 2014 - 07:30 PM
If you rev up to 2500 or so, does the voltmeter go higher. I think 14.5 would be OK as long as it doesn't go much higher.
#172 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted February 21, 2014 - 10:41 PM
Thanks for the update.
After all the work you've done, I agree, change out the voltage regulator, while
you're at it.
Looks like volts are running a bit high, for the rpm's  you where at.
As for this.....
Don't you guys have shopping malls over there? :D  :D
#173 cheluIS OFFLINE
cheluIS
  • 164 Thanks
  • 100 posts
Posted February 22, 2014 - 09:11 AM
@IamSherwood
We have a few malls but my better half is not much of a shopping addict . I had to pay for my "tractor madness" with a 12 days 5 stars all inclusive stay at seaside abroad . :boo_hoo:  It was much , much cheaper to send her shopping.
I installed the implement drive clutch pedal . I didn't had the original spring so I had to make an adaptation .
I don't like how the pedal pulley sits . It seems that is a litle inclined .Please take a look and tell me if this is OK.
Brought inside the tiller I started 2 years ago for my homemade tractor . It was to heavy to lift it by hand at my old tractor.Now I have power lift !
and some pics. from the beggining of construction.
Have to make the connection from the implement pulley and the tiller pulley .And obtain at the tiller a 200-250 revs/min .
Keep in touch
  • IamSherwood, Newpaws493 and Gabriel have said thanks
#174 DH1 OFFLINE
DH1
    Electric Tractors
  • 5495 Thanks
  • 5633 posts
Posted February 22, 2014 - 09:43 AM
@IamSherwood
I think if you move the crank pulley out a bit it will line up better.
  • cheluIS said thank you
#175 Gabriel OFFLINE
Gabriel
  • 1453 Thanks
  • 1868 posts
Posted February 22, 2014 - 10:35 AM
That tiller looks great! It will be fun to watch your progress on it! I don't have any experience with an MF 12, but do you think the engine will have enough power for that size of tiller?
#176 MH81 OFFLINE
  • 30052 Thanks
  • 29761 posts
Posted February 22, 2014 - 05:42 PM
I think the pedal piece may be bent slightly. It is also possible the crank pulley is on to far, but check the drive belt for alignment, that will tell you for sure.
#177 Gabriel OFFLINE
Gabriel
  • 1453 Thanks
  • 1868 posts
Posted February 24, 2014 - 08:38 PM
Have you made any progress on your MF 12, or your tiller?
#178 cheluIS OFFLINE
cheluIS
  • 164 Thanks
  • 100 posts
Posted February 25, 2014 - 07:26 AM
Out of town.Write from my phone.Update soon.
  • MH81, HowardsMF155 and Gabriel have said thanks
#179 cheluIS OFFLINE
cheluIS
  • 164 Thanks
  • 100 posts
Posted February 25, 2014 - 04:47 PM
Didn't had time to post what I've done in weekend .
Found some pulleys in store , don't like it very much becouse are made from aluminium .But I think will work .
Made a kind a gearing plan . Hope my knowledge from school and what I found on the internet are good .
My reasoning is that if I have 1.000RPM at engine I will have aprox 250RPM at tiller . Please , if someone is better than me at this post an opinion.
I pull out the implement pulleys ensemble and reverse it . The bigger pulley is outside . Pull out the smaller pulley and put a even smaller one - to gear down .
The rest you can see in the drawing.
Made on the lathe a spindle for the second ensemble .
Have to make the bearings housing from the blanks.
Hope it will work .
And I made a test with a 165kg weight (360lbs):
Keep in touch .
Edited by cheluIS, February 25, 2014 - 06:00 PM.
#180 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted February 25, 2014 - 06:13 PM
I came up with the same final RPM result, using this calculator.
http://www.culvermot...Calculator.html
Well actually 251.79
