New Mf12G Owner
203 replies to this topic
#151 cheluIS OFFLINE
cheluIS
  • 164 Thanks
  • 100 posts
Posted February 11, 2014 - 04:46 PM
I began the wiring .
And a little indiscretion . DEXTER Laboratory : :watch_over_fence:
Keep in touch .
  • MH81, IamSherwood, HowardsMF155 and 2 others have said thanks
#152 cheluIS OFFLINE
cheluIS
  • 164 Thanks
  • 100 posts
Posted February 16, 2014 - 09:33 AM
Close to finish .
Had this holes in the front grill :
This is the best I found to cover .
And for symmetry in the back .
A lot of work for fuel level .It works well.
Finished all the wiring exception the revmeter and the ignition switch .A lot of wires.!
For the ignition I think I have the solution but for revmeter I have to study deep.
I put a 100 Amps. switch to kill the battery in case something goes wrong.
And of course a horn .
A small presentation :http://youtu.be/y18iNEj6gDM
  • DH1, MH81, IamSherwood and 2 others have said thanks
#153 HANKG OFFLINE
HANKG
  • 6961 Thanks
  • 3671 posts
Posted February 16, 2014 - 09:43 AM
cool tractor welcome aboard
  • cheluIS said thank you
#154 sodisr OFFLINE
sodisr
  • 663 Thanks
  • 773 posts
Posted February 16, 2014 - 10:42 AM
CheluIs:
    Been following your'e thread and progress......  You do some outstanding work. !!
#155 HowardsMF155 OFFLINE
  • 3079 Thanks
  • 3084 posts
Posted February 16, 2014 - 11:42 AM
That is really going well.  Thanks for continuing to keep us updated.
#156 Sawdust OFFLINE
Sawdust
  • 6794 Thanks
  • 3799 posts
Posted February 16, 2014 - 11:46 AM
Nice job & like always it's interesting to find out what your doing next. :thumbs:
#157 MH81 OFFLINE
  • 30052 Thanks
  • 29761 posts
Posted February 16, 2014 - 01:16 PM
Nice updates. It will be interesting to see the solution you come up with on the revmeter (also called a tachometer)
#158 cheluIS OFFLINE
cheluIS
  • 164 Thanks
  • 100 posts
Posted February 16, 2014 - 01:43 PM
My tachometer (in romanian tahometru-I used the word revmeter becouse is more popular) is for 4 strokes and 2.4,6 or 8 pistons . The MF engine is with 1 piston so when I take the signal from coil I have to make somekind of divisor (I think). This field (engines and automotive electrics) is new for me so I have to dig .Hope to solve this .
Keep in touch.
#159 New.Canadian.DB.Owner OFFLINE
  • 2551 Thanks
  • 1620 posts
Posted February 16, 2014 - 03:58 PM
Most small engines spark on every revolution.  If yours does that, it may work fine on the two cylinder setting.
  • MH81 and cheluIS have said thanks
#160 Gabriel OFFLINE
Gabriel
  • 1453 Thanks
  • 1868 posts
Posted February 17, 2014 - 10:16 AM
Thanks for all the pictures! It's been fun watching your progress!
#161 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted February 17, 2014 - 08:20 PM
That's turning out to be a real nice tractor. You've done some very fine upgrades to it.
What's next?
Are you missing the tin that goes on top of the cylinder head? I think I have an extra one
laying around here if you're interested. It's small and light enough, postage shouldn't
cost too much. You're welcome to have it.
  • Sawdust and cheluIS have said thanks
#162 cheluIS OFFLINE
cheluIS
  • 164 Thanks
  • 100 posts
Posted February 18, 2014 - 04:24 PM
@IamSherwood Thank you for your offer.You are very kind . I let you know by PM .
Next I have to connect the tachometer .
After this I have to make the tiler . For this I have to put the implement drive clutch pedal that I bought from eBay (from USA).I didn't studied it very well but it seems that is not fitting well.
#163 cheluIS OFFLINE
cheluIS
  • 164 Thanks
  • 100 posts
Posted February 19, 2014 - 10:37 AM
A little help please .
I discovered that my charging unit from my Tecumseh HH 120 (the one with big radiator) is home made and in a bad shape . Any chance to find one to buy , original or replacement ? A link or something ?And the part no.
Thank you .
Edited by cheluIS, February 19, 2014 - 10:39 AM.
#164 MH81 OFFLINE
  • 30052 Thanks
  • 29761 posts
Posted February 19, 2014 - 12:36 PM
On many of those units, the charging unit is part of the CDI system. (Assuming it is under the flywheel) Please do a little research first on that. If you pull the flywheel off and take a picture, it might help us help you.
#165 cheluIS OFFLINE
cheluIS
  • 164 Thanks
  • 100 posts
Posted February 19, 2014 - 01:26 PM
The charging unit is under the fuel tank .You can see the radiator and the three wires that comes from engine .
One more thing .I want to connect the  tachometer before the pulse transformer .
Here I suppose I have signal strong enough . Any opinions?
But to reach to this point do I have to remove the cover of engine ?
To remove the cover I have to remove the fuel tube which is through the metal housing .
