Will a mower deck for a Cub Cadet 125 fit on a Cub Cadet 124........No modifications?
Will A 125 Deck Fit On A 124?
#1
ONLINE
Posted September 06, 2013 - 02:55 PM
#2
OFFLINE
Posted September 06, 2013 - 03:02 PM
Yes the deck will fit with out any problems. The only difference between the two models is that the 125 is a hydrostatic drive tractor and the 124 is a gear drive tractor other than the driveline they are the same tractor.
Edited by farmerall, September 06, 2013 - 03:32 PM.
- EricFromPa and VintageIronCollector have said thanks
#3
ONLINE
Posted September 06, 2013 - 03:15 PM
Yes the dick fit with out any problems.
Yes it will fit.That's the awesome thing about older early 1960s-1980 Cub Cadets.You can use Any Cub Cadet deck without Any modifications with the exception of the Cub Cadet Original.
I'm pretty sure you can even use a Super Cub deck on the old cubs but horse power will more than likely be an issue if you attempt that.
- motobreeder said thank you
