Points&condenser For Ss14
9 replies to this topic
#1 Bill56 OFFLINE
  • 839 Thanks
  • 2,179 posts
Posted September 05, 2013 - 06:17 PM
Anyone know of a source for points and condenser for 14 HP Briggs? All my local parts searching has been dead ends.
Model 320421-0132-01
Thanks, BILL
#2 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted September 05, 2013 - 07:30 PM
I've got them here, Bill.
Points are a 298185.
Condenser is a 298160.
Thanks!
Ben W.
  • olcowhand, Bill56, MH81 and 1 other said thanks
#3 chris m OFFLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted September 05, 2013 - 07:49 PM
Thanks!
Ben W.
LOL! I at least can verify that the numbers I found ( took over an hour) match the numbers you have Ben. :D It was a fun hunt for the numbers though ! :rolling:
  • superaben said thank you
#4 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted September 05, 2013 - 08:01 PM
I ought to hire you then.  :thumbs:
Actually, just between the wall and you, I cheat since I have a not-so-intuitive-but-it-works-for-my-brain quick cross reference for many of the old engines.
Ben W.
  • chris m said thank you
#5 chris m OFFLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted September 05, 2013 - 08:08 PM
Ben W.
I like a good challenge lol. I just noticed the Condenser # I found is a 298060 is it still the same as your 298160?
  • Bill56 and superaben have said thanks
#6 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted September 05, 2013 - 08:28 PM
My fingers must have been high on something, since 298060 is 100% the correct one.  I like swapping numbers, it messes everyone up.  :mad2:
You're hired.  You start Monday.
Ben W.
  • KennyP and chris m have said thanks
#7 Bill56 OFFLINE
  • 839 Thanks
  • 2,179 posts
Posted September 07, 2013 - 07:38 AM
 How do I go about ordering the parts?
   I have the day off and since this is for my mowing tractor, and the grass is already too long, I'm going to make one last attempt to find the parts locally (wishful thinking).
Thanks, again, for the information.
BILL
#8 Bill56 OFFLINE
  • 839 Thanks
  • 2,179 posts
Posted September 07, 2013 - 08:21 PM
I ended up finding the parts at Napa. Never would have thought to try looking there if it hadn't been for looking in my ''GTTalk notebook.'' Someone,a couple years ago, had made a post about finding points at Napa so I thought I'd give it a try. Planning on installing the parts tomorrow. Hopefully this will cure the problem.
#9 Bill56 OFFLINE
  • 839 Thanks
  • 2,179 posts
Posted September 16, 2013 - 07:23 PM
Took me a while to get a follow up posted... Got the points and condenser installed. I had some problem setting the point gap. My guage that I normally use had gotten wet and the number sizes were totally unreadable. I have other guages, but this is the tractor I use at my mom's place, so I took a guess on which was the right one to use. I checked my choice with another guage when I got home and found that my "guess" was one size under. It was a little sloppy of a fit, so I think I'm pretty close to being right.
Put everything back together and It started on the first pull. :dancingbanana:
   The battery went dead on this tractor, several years ago, so I did the "Sears emergency start" by taking off the flywheel cover and doing the rope start thing. It almost always started on the first pull, so I have been starting it that way ever since. (It actually starts quicker than it ever did using the starter)!
#10 MH81 OFFLINE
Posted September 16, 2013 - 07:30 PM
Glad she's a runner again. I have a Massey that is pull start
