B10 Gear Box
10 replies to this topic
#1 DanP OFFLINE
DanP
  • 330 Thanks
  • 491 posts
Posted September 05, 2013 - 01:03 PM
I was driving my B10 this weekend and all of a sudden it quit moving. The input shaft is moving but the output shaft is not. I suspect a key is sheared but don't know which one. My question is how much do I have to tear apart to get it out? I remember it was one of the first things I put in when I put it together and it is all painted up and I hate tearing it all apart.
#2 suburban 12 OFFLINE
suburban 12
  • 397 Thanks
  • 325 posts
Posted September 05, 2013 - 01:46 PM
Are you asking what you have to take apart to get the gear box out or to get the part out of the gearbox?
#3 boyscout862 ONLINE
  • 15179 Thanks
  • 9996 posts
Posted September 05, 2013 - 02:05 PM
Check the manual in our "manuals" section. Good Luck, Rick
There are keys on the input and output shafts. They can be replaced without removing the box.
Edited by boyscout862, September 05, 2013 - 02:25 PM.
  • DanP said thank you
#4 DanP OFFLINE
DanP
  • 330 Thanks
  • 491 posts
Posted September 05, 2013 - 10:17 PM
Yes I was wondering how to get the gearbox out of the GT
#5 MH81 OFFLINE
  • 30055 Thanks
  • 29761 posts
Posted September 05, 2013 - 10:35 PM
The bgb cover is accessible with a little removal of stuff and double jointed fingers. To get the whole bgb out, it's a project.
#6 suburban 12 OFFLINE
suburban 12
  • 397 Thanks
  • 325 posts
Posted September 06, 2013 - 08:45 AM
I couldn't agree more. You need to take the dash tower off, that includes disconnecting the shifter, steering column(or removing the steering wheel), wiring/cables, the drive shaft, and then unbolting it. It is possible to leave the wiring and cables connected but would be easier to have the dash completely off. This is based off of what I had to do to my B210, don't remember the exact differences between the B10 dash style and that one. I have an extra gear box that came out of a B10 that I parted out if you are interested.
#7 DanP OFFLINE
DanP
  • 330 Thanks
  • 491 posts
Posted September 06, 2013 - 12:04 PM
I have not had time to work on it yet. I am hoping it is on the outside shaft.
#8 DanP OFFLINE
DanP
  • 330 Thanks
  • 491 posts
Posted October 14, 2013 - 04:24 PM
Well I got it apart and that is a big job, even bigger job touching up the paint. The key had fallen out of the gear. How I do not know but some how it came out. I worked fine for a while but then just quit turning. I put a washer between the gear and brg to take care of some end play but I don't think there was enough play to let the key come out?
#9 MH81 OFFLINE
  • 30055 Thanks
  • 29761 posts
Posted October 14, 2013 - 04:50 PM
It almost had to slide that shaft one way or another. Check to see if the pullies are all tight on both sides.
#10 DanP OFFLINE
DanP
  • 330 Thanks
  • 491 posts
Posted October 17, 2013 - 01:21 PM
Well I got it all back together and the paint on the bolts all touched up. I drove it around for a while and all seamed fine. I still don't know how that key came out, but stranger things have happened.
#11 BairleaFarm OFFLINE
BairleaFarm
  • 1366 Thanks
  • 1788 posts
Posted October 17, 2013 - 01:24 PM
Glad you got it back together and it was a simple fix. I loose keys on my 410. I dont know if the bgb is thw same. There's room for the keys to slide out.
Sent from my SCH-I535 using Tapatalk
